29487 Discussions
/ifort-18_0: command line: warning #10006: ignoring unknown option '-no-standard-semantics'
Liu__Xiaoying
I have installed Xcode 8.3.3 and Intel Parallel Studio XE Composer Edition for Fortran macOS 2018. Then, I created an Xcode project - selected the Intel Compiler - added a new Fortran source file. Then, after I built with Xcode, the warning appeared like: "/ifort-18_0: command line: warning #10006: ignoring unknown option '-no-standard-semantics' ." Anyone can help me solve this problem? Thanks very much!!!
FortranFan
See this:
https://software.intel.com/en-us/fortran-compiler-18.0-developer-guide-and-reference-standard-semantics
Note -stand is only a diagnostic option, it doesn't affect code compilation and program behavior, whereas -standard-semantics can.
jimdempseyatthecove
If you omit -standard-semantics, it implies the option is OFF.
You might want to look at the documentation regarding:
-nostand
-stand [keyword]      (keyword = none, f90, f95, f03, f08, f15)
Jim Dempsey
FortranFan
See this:
Liu__Xiaoying
Thanks a lot for your kind help, and problem has been solved according to the link you provided.
FortranFan wrote:
See this:
https://software.intel.com/en-us/fortran-compiler-18.0-developer-guide-a...
