29595 Discussions
ifort 8.1 read or write big binary arrary errors ?
guoquan
Software:
ifort 8.1.024
Gentoo linux
kernel 2.6.11
glibc 2.3.5
Box:
HP DL590
4 Itatium-1 800MHz CPUs
32G memory
when I try to I/O some big binary arrays. I caught Segmentation fault
Examples:
1.
integer, parameter :: nc=416
integer, parameter :: hc=nc/2
integer, parameter :: np=hc**3
integer, parameter:: nn=2
integer :: nploc(nn)
real, dimension(6,np/nn*2,nn) :: xv_out
write(12) xv_out(1:6,1:nploc(i),i) !! here cause segmentation fault
the size of output file is a few hundred MB
2 or read from the the big file
just like before
read(12) xv_out(1:6,nploc(i),i) !! cause segmentation fault
the arrays I want to input or output is just a part of the arrays I defined.
but If dynamic allocate a arrays ,then output the new one , it workslike:
allocate (tmp_xv(6,nploc(i),1))
tmp_xv=xv_out(1:6,nploc(i),i)
write(12) tmp_xv
or
do j=....
do k=....
do i=.....
write(12) xv(i,jk )
enddo
enddo
enddo
although it worked slowly but without problem
I feel really confused about these .
Try a more recent compiler to see if it helps. We made some improvements in the way the stack was used in I/O statements.
guoquan
Where Can I get the most recent vesion ifort ?
From Website the most recent version ifort is 8.1.024,
which is just the version I am using.
Thank you
8.1.028 is the most recent. It is available from File Downloads at Intel Premier Support. You need to have registered your serial number in order to get at this, and non-commercial users can't getr updates.
Consider using an implied DO loop as an alternative.
guoquan
Will ifort version 8.1.28 be released to no-commercial users ? I hope it will :smileyhappy:.
When you get a non-commercial license, you are licensed for the current version but not updates.
Intel_C_Intel
guoquan, did you test your cases with flag -O3 / -O2 in the compile to see what willhappen?
