29559 Discussions
ifort and ifx internal compiler error
ronaldorpela
When I try to compile the following code
program main
  implicit none
  real(8), allocatable :: x(:,:,:)
  complex(8), allocatable :: z(:,:,:)
  allocate( x(5,4,3), source=1.0d0 )
  allocate( z, source=cmplx( x, 0.d0, kind=8))
end program
I observe an internal compiler error with both ifort and ifx. However, with gfortran, the code compiles without issues. Does it not conform to the fortran standard, or is it a bug with the intel compiler?
Here are the versions used
ifort --version
ifort: remark #10448: Intel(R) Fortran Compiler Classic (ifort) is now deprecated and will be discontinued late 2024. Intel recommends that customers transition now to using the LLVM-based Intel(R) Fortran Compiler (ifx) for continued Windows* and Linux* support, new language support, new language features, and optimizations. Use '-diag-disable=10448' to disable this message.
ifort (IFORT) 2021.13.0 20240602
Copyright (C) 1985-2024 Intel Corporation.  All rights reserved.
Devorah_H_Intel
The fix for this issue will be included in the next 2025 ifx release.
ronaldorpela
ifx --version
ifx (IFX) 2024.2.0 20240602
Devorah_H_Intel
I was able to reproduce the ICE. This case is now escalated to the compiler development team.
Thank you for the report.
Devorah_H_Intel
bharper
I have a similar ifx "internal compiler error" as per below attached code
ifx -c ifx_test.f90
Intel(R) Fortran Compiler for applications running on Intel(R) 64, Version 2024.0.0 Build 20231017
Copyright (C) 1985-2023 Intel Corporation. All rights reserved.
xfortcom: Fatal: There has been an internal compiler error (C0000005).
compilation aborted for ifx_test.f90 (code 1)
Steve_Lionel
Please start a new thread for this - just because the error message is the same that doesn't mean it's the same problem. Tacking on to an unrelated issue can delay a response.
