ifort: command not found
Guang_L_
$ source /opt/intel/bin/compilervars.sh intel64
~$ ifort
Can anyone tell me why?  Many thanks
I had installed the parallel_studio_xe_2016_update2 successfully on Ubuntu 14.04 TLS
Is ifort present in /opt/intel/bin ? Did you have ifort working with an earlier install?
Guang_L_
Thank you, Steve.
it seems that there is ifort in /opt/intel/bin
/opt/intel/bin$ ls -l ifortvars.sh
lrwxrwxrwx 1 root root 52 Mar  1 17:37 ifortvars.sh
I have the ifort working with the earlier install (you are powerful). I just reinstalled the Ubuntu 14.04 yesterday.
You show ifortvars.sh but not "ifort". So you reinstalled Ubuntu - did you also make sure that you have the required gcc/g++ installed?
Guang_L_
Thanks, Steven.
You are right. Ifort is also here.
lrwxrwxrwx 1 root root 52 Mar  1 17:37 ifort ->
 I have the gcc version 4.8.4 (Ubuntu 4.8.4-2ubuntu1~14.04.1)
$ gcc -v
Shall I update it?
The "source" command should have added the /opt/intel/bin directory to "path". I suggest you look at that to see if it got added.
Guang_L_
After adding the following sentence, it woks now. Many thanks
$ ifort
ifort: command line error: no files specified; for help type "ifort -help"
export PATH=$PATH:/opt/intel/bin
