ifort:command not found
adrian_k10
Hi
I'm tyring to get ifort working for the first time on fedora 12 (I'm using tcsh). When I try to compile something I get "ifort:command not found". If I try
/opt/intel/Compiler/11.1/072/bin/intel64 program_name.f90
the response is
"/opt/intel/Compiler/11.1/072/bin/intel64:permission denied"
and I also tried writing
source /opt/intel/Compiler/11.1/072/bin/ifortvars.csh intel64
in .mycshrc
but this didn't change anything....what should I do??
thanks alot
Ron_Green
From a terminal window
which ifort
ifort program_name.f90
this should work. If not, what is the output from those 3 commands - cut an paste the output so we can see what is going on.
ron
adrian_k10
Hi Ron
Thanks alot for your help.
Now when I try and compile something with ifort program_name.f90 I get
/opt/intel/Compiler/11.1/072/bin/intel64/fortcom: error while loading shared libraries: libstdc++.so.5: cannot open shared object file: No such file or directory
ifort: error #10273: Fatal error in /opt/intel/Compiler/11.1/072/bin/intel/fortcom, terminated by 0x7f
I assume that I need to do yum install/provide libstdc++.so.5/ or something??
(The first two commands that you suggested had no output...)
Thanks heaps for your help
Adrian
TimP
As discussed several times on these forums, you probably need the compat-libstdc++-33 (both 32- and 64-bit).
adrian_k10
thanks alot its working now
