ifort: command not found
Grey_E_
The problem that I'm experiencing seems to have been reviewed in these forums quite a bit but those solutions haven't solved it for me for whatever reason. My problem is that when I call ifort I receive a "command not found" response.  I successfully installed the compiler and then called compilervars.sh ia32 but still nothing.  I even tried creating a "custom.sh" file in etc/profile.d/ and then putting <install dir>/ifort but that didn't work either.  Does anyone have an idea as to what my problem is?  Thanks so much.
mecej4
If you run the shell script compilervars.sh directly, it will set the necessary environmental variables, but the old environment is reinstated as soon as the shell script completes. The proper command to use is source compilervars.sh ia32
Grey_E_
Yes, that worked. Thanks so much.
