ifort does not remove temps when using -syntax-only
ereisch
New Contributor II
Attempting to compile a file that requires preprocessing, the output of the preprocessor is saved in the current working folder, irrespective of the -[no-]save-temps and -[no]keep flags.  If you compile a file that has a .fpp extension (using the "-c" flag, for example on "test.fpp"), you only receive the output file as test.o in the working folder.  However, if you run the same compiler switches but replace the "-c" with "-syntax-only", the compiler leaves the "temp.i" file in the current folder.
Using ifort 18.0.5
Juergen_R_R
Valued Contributor II
I don’t get what the question is?
ereisch
New Contributor II
Not a question, a potential bug report.
ereisch
New Contributor II
I would like to bump this issue, as it is also present in 19.1.3.304, and occurs in more cases than just "-syntax-only".  We are now beginning to make heavier use of the preprocessor, and whenever the "-fpp" flag is set, the intermediate ".i" files are always created (and left behind) in the current working folder.  This is regardless of whether the "-no-save-temps" flag is set.
Also, to reduce filesystem thrash (especially when working on networked filesystems), it would be convenient to offer an equivalent of the gcc "-pipe" flag:
-pipe: Use pipes rather than temporary files for communication between the various stages of compilation.
ereisch
New Contributor II
EDIT: Digging into this a bit more, it seems to only occur when "-syntax-only" is set.
