Do you know what does this error mean? If i run ifort simple it says the usuual error , that no input file was given. If I try to compile a file in using command line I get this error: "ifort: error: could not find 'Bin'".
Cristian
Cristian
You did not have one of the required Microsoft products installed (Visual C++.NET 2002 or 2003, or Visual Studio.NET 2002 or 2003). When you obtain and install one of these, uninstall and reinstall Intel Fortran.
I have the same problem as well, except that I already have MS Visual Toolkit C++ 2003 installed prior to the FORTRAN installation. Since then I have unistalled and re-installed but have not been able to bypass this message.
Any other ideas?
Ram
Visual C++ Toolkit is not the same as Visual C++ Standard Edition or higher. See here for information on setting things up with the Toolkit.
