29359 Discussions
ifort fails to respect the OpenMP task despendency
BSC_support
Build Number: OneApi 2021.3.0
Environment: Linux 4.4.59-92.20
Reason: Defect
Description: The binary generated by ifort fails to respect the OpenMP task dependencies between tasks instantiated in a subroutine and the ones instantiated in its internal subroutines.
Observations: Works properly when the variable that creates the dependency is ALLOCATABLE or the array has constant explicit shape.
Steps to Reproduce:
1) Compile the attached test (test.f90) with:
     ifort -qopenmp -f test.exe test.f90
2) Set OMP_NUM_THREADS biger than 1
3) Run the test.exe
4) The output of the second task is printed before the first one, which implies that the dependency is not respected.
Expected Result: The tasks execution respects the order specified by the dependencies: the first task completes its execution before the second one starts.
Labels (2)
ShanmukhS_Intel
Thanks for reaching out to us. We are working on your issue. We'll get back to you soon.
Shanmukh.SS
Khalik_K_Intel
Thank you for contacting Intel Support.
We have reproduced the behavior on our end and it looks like a bug in Intel Fortran Compiler.
I have now passed the information to Intel Fortran development team to have a look.
I will post an update once we get information from the development team.
In the meantime we are glad that you have a workaround available.
Khalik.
BSC_support
Thank you Shanmukh and Khalik.
Barbara_P_Intel
I realize this fix took some time to come. But the reproducer is now compiling and running successfully with ifx 2023.0.0. This compiler was released in December as part of oneAPI HPC Toolkit 2023.0.
Give it a try!
