29391 Discussions
ifort/ifx: Emit preprocessor output and compilation output in a single invocation
Erbic
I am using ifort on the command line on Windows 10. Here are the relevant flags:
This will pre-process and compile myfile.f90 and emit myfile.obj:
ifort -fpp -compile-only -object:myfile.obj myfile.f90
This will pre-process myfile.f90 and emit the pre-processed file to stdout, but it will NOT emit myfile.obj:
ifort -fpp -E -compile-only -object:myfile.obj myfile.f90
Is there some combination of flags that will allow me to emit both the pre-processed file and the object file in a single invocation?
Labels (2)
