ifort in Docker container
Stainer__Thomas
Is it possible to have a version of the ifort compiler inside a docker image which then hosted on Docker Hub?
Would there be any issues with having the compiler on Docker Hub (public) even if no license was in the image?
Does this require a special license?
Eugene_E_Intel
I will find out.
If it's possible for us to do this, which OS would you want for the container?  There are various flavors of Linux, but I believe this is the only official Windows container: https://hub.docker.com/r/microsoft/windowsservercore/
Thank you,
Eugene
Stainer__Thomas
Hi Eugene,
Thank you for getting back so promptly.
I now realize that I have posted this message in the Windows section, but it would actually refer to any OS system inside a Docker image. Which would include the likes of Ubuntu, Solaris, Opensuse and possibly Windows.
Tom
Andreas_A_
I wanted to install Fortran in a Windows docker container. Unfortunately I was not successful.
Visual Studio is already installed inside the container. I attached the log files from the container.
Can you please assist me?
Best regards
Andreas
Andreas_A_
No idea? :-)
The same command worked with a clean Windows 10 installation with vs 2013
CSlat2
Any update to this?
We would like to be able to put together a number of docker images that pair up compilers. i.e.
Windows:
                 MSVS 2015 and Intel 15 FORTRAN
                 MSVS 2017 and Intel 18 FORTRAN
Linux
                 Gcc and Intel 18 FORTRAN
All of these acessable via a Dockered Jenkins
