ifort linking error
simon932
Dear all,
I am getting the following error at the final linking step for a fortran90 program:
ifort -c -O3 -xsse4.2 -axsse4.2 -msse4.2 -parallel -threads -unroll=1024 -opt-prefetch=3 -standard-semantics -assume byterecl -openmp -I/cm/shared/apps/intel/composer_xe/current/mkl/include/intel64/lp64 -I/cm/shared/apps/intel/composer_xe/current/mkl/include main.f90
ifort -o Myprogram.run -L/cm/shared/apps/cuda50/toolkit/current/lib64 -lcudart -lcufft /usr/lib64/libpthread_nonshared.a -O3 -xsse4.2 -axsse4.2 -msse4.2 -parallel -threads -unroll=1024 -opt-prefetch=3 -standard-semantics -assume byterecl -openmp -I/cm/shared/apps/intel/composer_xe/current/mkl/include/intel64/lp64 -I/cm/shared/apps/intel/composer_xe/current/mkl/include main.o -lpthread_nonshared -openmp -lstdc++ -I/cm/shared/apps/intel/composer_xe/current/mkl/include -Wl,--start-group  /cm/shared/apps/intel/composer_xe/current/mkl/lib/intel64/libmkl_blas95_lp64.a /cm/shared/apps/intel/composer_xe/current/mkl/lib/intel64/libmkl_lapack95_lp64.a /cm/shared/apps/intel/composer_xe/current/mkl/lib/intel64/libmkl_scalapack_lp64.a -Wl,--start-group  /cm/shared/apps/intel/composer_xe/current/mkl/lib/intel64/libmkl_cdft_core.a /cm/shared/apps/intel/composer_xe/current/mkl/lib/intel64/libmkl_intel_lp64.a /cm/shared/apps/intel/composer_xe/current/mkl/lib/intel64/libmkl_intel_thread.a /cm/shared/apps/intel/composer_xe/current/mkl/lib/intel64/libmkl_core.a /cm/shared/apps/intel/composer_xe/current/mkl/lib/intel64/libmkl_blacs_intelmpi_lp64.a -Wl,--end-group /cm/shared/apps/intel/composer_xe/2011_sp1.12.361/compiler/lib/intel64/libiomp5.a -lpthread -lm -L/usr/local/lib  -lspmv -L/usr/local/lib -lsundials_fkinsol -lsundials_kinsol -lsundials_fcvode -lsundials_cvode -lsundials_fnvecserial -lsundials_nvecserial -lsundials_fida -lsundials_ida  -openmp-link static -openmp
ipo: remark #11000: performing multi-file optimizations
ipo: remark #11006: generating object file /tmp/ipo_ifortB5onkc.o
/cm/shared/apps/intel-cluster-runtime/3.6/composer_xe_2013_sp1.0.080/compiler/lib/intel64/libifport.a(utility_alloccstr.o): In function `allocCstr':
/export/users/nbtester/efi2linux_nightly/branch-14_0/20130730_000000/libdev/libifport/portability/utility_alloccstr.c:(.text+0x45): undefined reference to `_intel_fast_memmove'
/cm/shared/apps/intel-cluster-runtime/3.6/composer_xe_2013_sp1.0.080/compiler/lib/intel64/libifcoremt.a(for_init.o): In function `for__signal_handler':
for_init.c:(.text+0x8ce): undefined reference to `_intel_fast_memmove'
for_init.c:(.text+0x8e7): undefined reference to `_intel_fast_memmove'
for_init.c:(.text+0x900): undefined reference to `_intel_fast_memmove'
for_init.c:(.text+0x919): undefined reference to `_intel_fast_memmove'
/cm/shared/apps/intel-cluster-runtime/3.6/composer_xe_2013_sp1.0.080/compiler/lib/intel64/libifcoremt.a(for_init.o):for_init.c:(.text+0x932): more undefined references to `_intel_fast_memmove' follow
This is on CentOS 6.4 and I am using the following version of ifortran:
ifort (IFORT) 12.1.6 20120821
I am quite beginner at this, and I was hoping someone more experienced could point me to what I might be doing wrong here.
Many thanks,
Simon
See this?
That tells me you have at least some 14.0 libraries in your linking path. You are getting a mix of 14.0 and 12.1 libraries and this causes the link errors. Check your build environment and make sure you are "source"ing the correct ifortvars.sh file.
See this?
simon932
Thank you, indeed executing 'source /cm/shared/apps/intel/composer_xe/2011_sp1.12.361/bin/ifortvars.sh intel64' before compiling solved my problem!
