ifort optimization bug?
kambrian
the following code runs erroneous when compiled with ifort 10.1-ia64 without specifying any compiler options:
[cpp]program testdo
implicit none
integer*4:: np,i,j
real*4,allocatable::arr(:,:)
np=1024*1024*1024;
allocate(arr(np,3))
forall(i=1:np,j=1:3)
arr(i,j)=i+0.1*j
end forall
write(*,*)  arr(1,1:3)
write(*,*) (arr(1,j),j=1,3)  ! seems to print arr(1,1) three times?
end program testdo[/cpp]
the result reads:
1.100000 1.200000 1.300000
1.100000 1.100000 1.100000
While using gfortran or using ifort -O0 -g, it runs correctly to print:
Yuan_C_Intel
Kambrian,
This problem has already been fixed in the 10.1.022compiler or 11.0 compiler. Please try this new version andreply tous if you have additional questions. You may download the latestpackagefrom our Registration Center: https://registrationcenter.intel.com/.
Yolanda Chen
Intel Developer Support
Tools Knowledge Base: http://software.intel.com/en-us/articles/tools
