29375 Discussions
ifort switch to show ld invoke commands?
jkwi
Swear I used this once but can't find it now.
Is there an ifort switch to force showing it invoking ld() and all commands passed to ld()?
jkwi
-v does most of the trick!
However, when fortcom is invoked there appear to be scripts read as in:
-mIPOPT_link_script_file=/tmp/ifortg6aJXdscript
But these are removed after ld() is invoked with a 'rm'. Any way to see these
files?
I tried -save-temps but that doesn't work.
Ron_Green
just use -dryrun
this captures everything in the compilation and link steps, but does not do an actual compilation or link.
TimP
Adding -# should show you what goes into the linker script during a live build.
