29362 Discussions
ifort: warning #10145: no action performed for file 'A.obj'
pascal_M_
I am under windows (as the obj extension shows).
I have two valid .f90 files `A.f90` and `B.f90` (place in the same folder) where `B.f90` uses `A.f90`, the code of `B.f90` being :
module B
use A
! ... stuff
The code of `A.f90` is
module A
! ... stuff
I compile `A.f90` with :
ifort -c -fpp A.f90
Now I would like to compile `B.f90` "while taking accound of" `A.f90`, that is, of its `.obj` file.
So I tried :
ifort -c B.f90 A.obj
which throws
at me.
Is the command
ifort -c B.f90
proper to compile `B.f90` "while taking accound of" `A.f90`, that is, of its `.obj` file ?
I would like B.f90 it to be compiled "as A.f90 is", as in fact I have a third C.f90(containing a use B) and that at the end I must run the command :
ifort -dll toto.dll A.o B.o C.o
to compile a dll while linking to all object files from A, B, C.
Lorri_M_Intel
When  you use "-c", as you did in this line:
you're telling the compiler you only want to create an object file, not an executable.
If B is using a module defined in A, you don't need to compile against the object file; the module information is stored in a file called A.mod.
For Windows, mod files are found in the INCLUDE path, or by passing the directory location using either /module:directory-path, or /include:directory-path
     Does this help?
                                 --Lorri
