ifort with MingW
Sagan__David
I have to use the MingW environment for a project on Windows due to some compile scripts not being workable under Visual Studio. I would like to use ifort with MingW but I don't know how to set this up (Note: I already use ifort with VS). Is this possible? Thanks for any help.
TimP
Do you mean that you use C - Fortran interoperability and wish to use gcc or g++ in place of ICL or C++?  This seems to imply run-time library conflicts, as the Microsoft libraries are required by ifort.
On the other hand, if you use gnu make or a shell such as bash, that should be feasible to use with ifort/cl command line.
Sagan__David
C - Fortran interoperability is needed eventually but for now I just want to be able to compile/link with ifort on the command line. Now if I type "which ifort" in MingW I get nothing so there is a setup that is needed and I am not able to find any information on the web on how to do this. Thanks for any help.
IanH
Start a normal ifort command prompt, then from within that command run x:\mingw\msys\1.0\msys.bat.  That should have you running in an msys shell environment (is that what you mean by "the MinGW environment"?) with all the ifort environment variables set correctly.
TimP
If Ian's advice results in ifort picking the wrong link command, you can set the -Qlocation,link option for ifort to point to the Microsoft VC\bin or VC\bin\amd64 folder where their link.exe resides.
I hesitated to answer along the lines which Ian did because I didn't know what you meant by MinGW environment, and didn't want to ask too many off-topical details.
Sagan__David
By "MinGW environment" I mean a shell running MinGW.  In response to Ian's post, I start with a shell with ifort setup (the ifort command is reognized). One problem now is that there is no file I can find with a name that is close to "msys.bat" (I am running msys2 not msys). So instead I run C:\msys64\mingw64.exe which spawns a shell running MinGW. Now the problem is that the ifort command is not defined.
Now in the MinGW shell I use the following commands to setup ifort:
  '/c/Program Files (x86)/Intel/Composer XE 2015/bin/ipsxe-comp-vars.bat' intel64 vs2010
  export PATH=${PATH}:'C:\Program Files (x86)\Intel\Composer XE 2015\bin\intel64'
But now using ifort the linking fails with  "link: unknown option --s". I assume this is the linker picking the wrong link command as per Tim's comment. However I don't understand how to "set the -Qlocation,link option".
Anyone have any ideas? -- Thanks.
andrew_4619
I guess there is a GNU link.exe earlier in the PATH than the Ifort linker.
IanH
So... I think you are using mingw-w64 and want to work in an MSYS2 environment running the bash shell or similar.  If so, as TimP suggests try something like:
>h:\msys64\usr\bin\bash.exe
ian@DOLORES  /u/projects/FortranMisc/2016
$ PATH=/bin:$PATH
$ cat 2016-08-17\ helloworld.f90
PROGRAM HelloWorld
  IMPLICIT NONE
  PRINT "(A)", 'Hello world'
END PROGRAM HelloWorld
$ ifort 2016-08-17\ helloworld.f90 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\bin\amd64"
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 17.0 Beta Build 20160517
Copyright (C) 1985-2016 Intel Corporation.  All rights reserved.
ifort: NOTE: The Beta evaluation period for this product ends on 7-oct-2016 UTC.
Microsoft (R) Incremental Linker Version 14.00.24213.1
Copyright (C) Microsoft Corporation.  All rights reserved.
"-out:2016-08-17 helloworld.exe"
-subsystem:console
"2016-08-17 helloworld.obj"
$ ./2016-08-17\ helloworld.exe
Hello world
TimP
No, the path set in location,link is the folder in the vs installation which contains link.exe. for intel64:
-Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\bin\AMD64"
Sagan__David
Thanks Ian and Tim. I found where the link.exe was but now I get a different error:
Etienne@Etienne-PC MINGW64 ~/bmad_dist
$ ifort Hello.f90 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\Intel Fortran\Microsoft Files\VC\Bin\amd64"
Intel(R) Visual Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 15.0.1.148 Build 20141023
Copyright (C) 1985-2014 Intel Corporation.  All rights reserved.
Microsoft (R) Incremental Linker Version 10.00.40219.01
-out:Hello.exe
-subsystem:console
Hello.obj
LINK : fatal error LNK1104: cannot open file 'ifconsol.lib'
Any thoughts? My environmental variables are:
$ printenv
HOMEPATH=\Users\Etienne
APPDATA=C:\Users\Etienne\AppData\Roaming
MANPATH=/mingw64/share/man:/usr/local/man:/usr/share/man:/usr/man:/share/man
ACC_CMAKE_VERSION=2.8.5
ACC_EXE=/home/Etienne/bmad_dist/production/bin
ProgramW6432=C:\Program Files
ORIGINAL_TEMP=/c/Users/Etienne/AppData/Local/Temp
HOSTNAME=Etienne-PC
ORIGINAL_TMP=/c/Users/Etienne/AppData/Local/Temp
DIST_OS=MINGW64_NT-6.1
INTEL_LICENSE_FILE=C:\Program Files (x86)\Common Files\Intel\Licenses
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 42 Stepping 7, GenuineIntel
TERM=xterm
SHELL=/usr/bin/bash
ACC_DEBUG=/home/Etienne/bmad_dist/debug/bin
KMP_DUPLICATE_LIB_OK=TRUE
WINDIR=C:\Windows
DIST_BUILD=TRUE
GINODATA=C:\Users\Public\Documents\gino\v8.0
ACC_BUILD_SYSTEM=/home/Etienne/bmad_dist/build_system
PGPLOT_FONT=/home/Etienne/bmad_dist/PGPLOT/grfont.dat
ACC_PLOT_DISPLAY_TYPE=QT
PUBLIC=C:\Users\Public
OLDPWD=/c/Users/Etienne/Desktop
CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files
G95_LIBRARY_PATH=C:\Program Files\g95\lib\gcc-lib\i686-pc-mingw32\4.1.2;C:\Program Files\g95\lib
USERDOMAIN=Etienne-PC
ORIGINAL_PATH=/c/Windows/System32:/c/Windows:/c/Windows/System32/Wbem:/c/Windows/System32/WindowsPowerShell/v1.0/
MSYSTEM_CHOST=x86_64-w64-mingw32
ALLUSERSPROFILE=C:\ProgramData
MIC_LD_LIBRARY_PATH=C:\Program Files (x86)\Common Files\Intel\Shared Libraries\compiler\lib\mic
OS=Windows_NT
IFORT_COMPILER15=C:\Program Files (x86)\Intel\Composer XE 2015\
windows_tracing_flags=3
BMAD_LAYOUT=/home/Etienne/bmad_dist/config/bmad/layout
GINO=C:\ginointel32
windows_tracing_logfile=C:\BVTBin\Tests\installpackage\csilogfile.log
USER=Etienne
TEMP=/tmp
COMMONPROGRAMFILES=C:\Program Files\Common Files
VS90COMNTOOLS=C:\Program Files (x86)\Microsoft Visual Studio 9.0\Common7\Tools\
temp=C:\Users\Etienne\AppData\Local\Temp
tmp=C:\Users\Etienne\AppData\Local\Temp
GCC_MINOR_VER=1
DIST_CONFIG=/home/Etienne/bmad_dist/config
ACC_BUILD_EXES=Y
IFORT_COMPILER13=C:\Program Files (x86)\Intel\Composer XE 2013\
QTJAVA=C:\Program Files (x86)\Java\jre6\lib\ext\QTJava.zip
DIST_F90=gfortran
CONFIG_SITE=/mingw64/etc/config.site
USERNAME=Etienne
ACC_COMPILER_TOOLSET=mingw64-msys
DIST_PLATFORM_VERSION=2
DIST_UTIL=/home/Etienne/bmad_dist/util
PROCESSOR_LEVEL=6
INTEL_DEV_REDIST=C:\Program Files (x86)\Common Files\Intel\Shared Libraries\
ACC_ENABLE_OPENMP=N
PATH=/mingw64/bin:/usr/local/bin:/usr/bin:/bin:/c/Windows/System32:/c/Windows:/c/Windows/System32/Wbem:/c/Windows/System32/WindowsPowerShell/v1.0/:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl:/home/Etienne/bmad_dist/util:C:\Program Files (x86)\Intel\Composer XE 2015\bin\intel64
BMAD_LAT=/home/Etienne/bmad_dist/config/bmad/lat
MINGW_PACKAGE_PREFIX=mingw-w64-x86_64
PSModulePath=C:\Windows\system32\WindowsPowerShell\v1.0\Modules\
FP_NO_HOST_CHECK=NO
SYSTEMDRIVE=C:
PWD=/home/Etienne/bmad_dist
VSSHELL2010INSTALLDIR=C:\Program Files (x86)\Microsoft Visual Studio 10.0\
DIST_BASE_DIR=/home/Etienne/bmad_dist
USERPROFILE=C:\Users\Etienne
LANG=en_US.UTF-8
ACC_ENABLE_SHARED=N
MSYSTEM_PREFIX=/mingw64
ACC_ENABLE_MPI=N
TZ=America/New_York
PS1=\[\e]0;\w\a\]\n\[\e[32m\]\u@\h \[\e[35m\]$MSYSTEM\[\e[0m\] \[\e[33m\]\w\[\e[0m\]\n\$
LOGONSERVER=\\ETIENNE-PC
DIST_MOD=/home/Etienne/bmad_dist/modules
CommonProgramW6432=C:\Program Files\Common Files
MINGW_CHOST=x86_64-w64-mingw32
LOCALAPPDATA=C:\Users\Etienne\AppData\Local
PROCESSOR_ARCHITECTURE=AMD64
DIST_ARCH=x86_64
DIST_SETUP_QUIET=N
ProgramData=C:\ProgramData
HOME=/home/Etienne
SHLVL=1
ACC_ROOT_DIR=/home/Etienne/bmad_dist
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
GCC_VER_STR=GNU Fortran (Rev1, Built by MSYS2 project) 6
USE_CWD_BASEDIR=Y
HOMEDRIVE=C:
MSYSTEM_CARCH=x86_64
GCC_MAJOR_VER=6
PGPLOT_DIR=/home/Etienne/bmad_dist/PGPLOT
COMSPEC=C:\Windows\system32\cmd.exe
MSYSTEM=MINGW64
TMP=/tmp
SYSTEMROOT=C:\Windows
PROCESSOR_REVISION=2a07
PRINTER=Canon MP990 series USB
ACC_SET_GMAKE_JOBS=1
DIST_EXE=/home/Etienne/bmad_dist/bin
DIST_INC=/home/Etienne/bmad_dist/include
CLASSPATH=.;C:\Program Files (x86)\Java\jre6\lib\ext\QTJava.zip
DIST_F90_REQUEST=gfortran
ACC_ENABLE_GFORTRAN_OPTIMIZATION=Y
PKG_CONFIG_PATH=/mingw64/lib/pkgconfig:/mingw64/share/pkgconfig
DIST_OS_ARCH=MINGW64_NT-6.1_x86_64
ACLOCAL_PATH=/mingw64/share/aclocal:/usr/share/aclocal
MINGW_PREFIX=/mingw64
INFOPATH=/usr/local/info:/usr/share/info:/usr/info:/share/info
ACC_PLOT_PACKAGE=plplot
NUMBER_OF_PROCESSORS=4
DIST_LIB=/home/Etienne/bmad_dist/lib
TAO_DIR=/home/Etienne/bmad_dist/tao
SESSIONNAME=Console
DIST_PLATFORM=MINGW64_NT-6.1_x86_64_gfortran
COMPUTERNAME=ETIENNE-PC
_=/usr/bin/printenv
Kevin_D_Intel
You need at least a LIB setting. You can get the needed details from an Intel compiler pre-initialized command-prompt. Command-prompt shortcuts are under a path like:
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Intel Parallel Studio XE 2015\Compiler and Performance Libraries\Command Prompt with Intel Compiler XE v15.0 Update 1
Start the command-prompt for the Intel 64 environment and then just echo it with:  echo %LIB%
Sagan__David
OK that worked. Much thanks.
Procedure was:
On intel side:
   echo %LIB%
On MingW side:
   export LIB='stuff-from-intel-side'
