ifort with NAG under 64-bit Windows
Valerie_L_
I am trying to migrate with my research code from Linux HPC cluster to 64-bit Windows (changed job recently and got a new PC).
The code is a set of Matlab and Fortran subroutines, which also call stand-alone NAG Fortran library. It all worked well in the old configuration with pgf90 compiler and Mark21 NAG library under Linux.
Now I have Mark23 NAG library and Intel 64 Visual Studio, of which I use 'ifort' in command line.
In my Makefile, the compilation lines are as follows:
LIBDIR = 'C:/Program Files/NAG/FL23/flw6i23dcl/bin/' LIBNAME = FLW6I23DC_nag.dll
OBJS1 = myprog.f ukf.f OBJS2 = contour.f cdens_subr.f potfit_subr.f
myprog: $(OBJS1)
$(FC) $(OBJS1) $(LIBDIR)$(LIBNAME)
 When I run the package (via Matlab envelope code), I get the following error message:
ifort myprog.f ukf.f 'C:/Program Files/NAG/FL23/flw6i23dcl/bin/'FLW6I23DC_nag.dll
Intel(R) Visual Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 13.0.0.089 Build 20120731
Copyright (C) 1985-2012 Intel Corporation.  All rights reserved.
ifort: command line warning #10161: unrecognized source type 'C:/Program Files/NAG/FL23/flw6i23dcl/bin/FLW6I23DC_nag.dll'; object file assumed
ipo: warning #11010: file format not recognized for C:/Program Files/NAG/FL23/flw6i23dcl/bin/FLW6I23DC_nag.dll
link: unknown option -- s
Try `link --help' for more information.
Makefile:15: recipe for target `myprog' failed
make: *** [myprog] Error 1
I also tried static library from the same Mark23, and it did not work either. Not to mention that I tried 'nagfor' compiler before that - I managed to obtain an executable, but it crashed at call saying about division by zero (which did not happen with 'pgf90').
I would be very grateful if you advised how to resolve the compilation issue with 'ifort'.
Thank you
Valerie Livina
You are trying to use Linux syntax for the command line and are still naming a DLL on the ifort line - this won't work. If you have the import .lib corresponding to this DLL, simply name it on the ifort line as if it were a source file.  However, you can't mix 32-bit and 64-bit code, so if the NAG library you are linking to is 64-bit, you need to do a 64-bit build of your application.
I see you are using the included Visual Studio Shell, which is fine. Have you by any chance installed any other Visual Studio products on this system, such as an "Express Edition" of Visual C++?
Valerie_L_
Dear Steve,
I installed 32-bit Mark22 NAG library and using IA-32 Visual Studio Command Prompt I compiled the code with NAG library by the following command
ifort myprog.f ukf.f "C:\Program Files (x86)\NAG\FL22\flw3222dcl\lib\FLW3222DC_nag.lib
It produces an exe-file, and I am certain that it works, because when I run the exe-file outside the matlab-package with input parameters in the command line, it generates an output series as it should. Now I have to adjust the Makefile to be able to run it using 'nmake' (so that I would not need to use Cygwin and just run Matlab from the IA-32 Visual Studio Command Prompt).
My Makefile is as follows:
OBJS1=myprog.f ukf.f OBJS2=contour.f cdens_subr.f potfit_subr.f
LIBNAME=FLW3222DC_nag.lib LIBDIR='C:\Program Files (x86)\NAG\FL22\flw3222dcl\lib\'
myprog.exe: $(OBJS1)
ifort $(OBJS1) $(LIBDIR)$(LIBNAME)
contourprog.exe: $(OBJS2)
ifort $(OBJS2) $(LIBDIR)$(LIBNAME) /exe:contourprog.exe
clean: del *.exe *.obj
When it is called, it produces the following error message:
 makefile(10) : fatal error U1034: syntax error : separator missing
I understand that nmake is different from make, but as I am reading various online manuals and examples, my simple makefile seems correct to me - would you please advise what is wrong with syntax there?
I found installed Microsoft Windows SDK, which also has its own Command Prompt, 64-bit configured and calling startup script
"C:\Program Files\Microsoft SDKs\Windows\v7.1\Bin\SetEnv.cmd"
However, since the 32-bit NAG library is working with my code now, I am happy with it and just want to adjust the Makefile to be able to use 'nmake', so I am looking forward to your advice regarding that.
Thank you
Valerie
I'm not an nmake expert - perhaps someone else can comment.
mecej4
Your makefile is defective (one reason may be that when you paste its contents into a post, tabs, which are rather important in makefiles, may get converted to spaces; line-breaks, which are also important to preserve in makefiles, can get mangled as well).
I have attached a fixed up makefile (remove the .txt suffix before using).
Valerie_L_
Dear mecej4,
Thank you very much for looking into this.
Yes, you are right: this is how the content of the file went into the webform by copy&paste, without linebreaks
I just saved it on my computer (without any editing) and attempted to run my codes with this Makefile - I got the following error messages:
LINK : fatal error LNK1104: cannot open file ''C:\Program.obj'
NMAKE : fatal error U1077: '"C:\Program Files (x86)\Intel\Composer XE 2013\bin\ia32\ifort.EXE"' : return code '0x450'
ifort: command line warning #10161: unrecognized source type ''C:\Program'; object file assumed
ifort: command line warning #10161: unrecognized source type 'Files'; object file assumed
ipo: error #11018: Cannot open 'C:\Program ipo: error #11018: Cannot open Files
ipo: error #11018: Cannot open (x86)\NAG\FL22\flw3222dcl\lib\'FLW3222DC_nag.lib
Strangely enough, when I got back to my old Makefile (where I added the line from your code that was missing in mine, all: myprog.exe contourprog.exe), removed all blank lines, and also added a slash as an additional separator (although it was given in the LIBDIR, it also wanted to see the slash as $(LIBDIR)\$(LIBNAME) in the call)
Now my code works! With your help, I have managed to migrate the package, at last.
I am very grateful to you guys, many thanks to Steve, too!
I was stuck with this task for several weeks, and NAG support could not help me with compilation (well, with Christmas break making my silly questions even sillier for them, I assume).
Thank you both very much!
Yours sincerely
Valerie
We're glad to hear it!
