ifortvars.csh error
ghatolesspun_matherp
I am tring to run ifortvars.csh script i am getting this error i am not unable to run this command ifort
can any one please help me.
/opt/intel/Compiler/11.1/069/bin/ifortvars.csh intel64
/opt/intel/Compiler/11.1/069/bin/ifortvars.csh: line 10: syntax error near unexpected token `"$1"'
eliosh
Your shell may not be cshell.
You also need "source" at the beginning of the line. See your other thread.
Ron_Green
You can confirm your shell with:
echo $0
and then if it is csh or tcsh, use this:
source ..../ifortvars.csh intel64
if bash, then
source ..../ifortvars.sh intel64
And you know that "...." is shorthand for your full path - use the full path, not 4 dots.
