ifx 2023.2.0 on wsl2
egio
I have just update my ubuntu WSL2 installation of the latest version of oneApi 2023.2.0 using:
sudo apt update
sudo apt upgrade
As usual I have recreated the module files launching:
...:/opt/intel/oneapi$ sudo ./modulefiles-setup.sh
from the linux prompt.
The problem is that no "compiler" module file is present anymore.
...:/opt/intel/oneapi$ module avail
-------------------------------------------- /opt/intel/oneapi/modulefiles ---------------------------------------------
advisor/2023.2.0 dnnl-cpu-gomp/2023.2.0 dpl/2022.2.0 mkl/2023.2.0 vtune/2023.2.0
advisor/latest dnnl-cpu-gomp/latest dpl/latest mkl/latest vtune/latest
ccl/2021.10.0 dnnl-cpu-iomp/2023.2.0 inspector/2023.2.0 mkl32/2023.2.0
ccl/latest dnnl-cpu-iomp/latest inspector/latest mkl32/latest
dal/2023.2.0 dnnl-cpu-tbb/2023.2.0 intel_ipp_intel64/2021.9.0 mpi/2021.10.0
dal/latest dnnl-cpu-tbb/latest intel_ipp_intel64/latest mpi/latest
debugger/2023.2.0 dnnl/2023.2.0 intel_ippcp_intel64/2021.8.0 oclfpga/2023.2.0
debugger/latest dnnl/latest intel_ippcp_intel64/latest oclfpga/latest
dev-utilities/2021.10.0 dpct/2023.2.0 itac/2021.10.0 tbb/2021.10.0
dev-utilities/latest dpct/latest itac/latest tbb/latest
I can still access the compilers sourcing the setvars.sh but I would like to use modulefiles.
Have you noticed something similar?
Barbara_P_Intel
Thanks for reporting this issue that the module files for the compiler are missing in oneAPI 2023.2. We are aware and working on a hotfix to help you.
I have anecdotal evidence that the compiler modulefiles from oneAPI 2023.1 work okay with oneAPI 2023.2.
Barbara_P_Intel
I expect to see a hot fix to the compiler that will deliver the modulefiles. Target is this week.
It will be a patch for oneAPI 2023.2.
Stay tuned.
Barbara_P_Intel
Ron just posted workarounds on this Forum post.
