29386 Discussions
ifx and ifort comparison for do concurrent
Fortran10
below is my do concurrent code:
Question 1) Why the code does not run in parallel with ifx? Apparently, I do not see any error or warning !
program dc_test
  implicit none
  integer(4),parameter::Nx=300,Ny=300
  real(8) :: x=0.03d0,y=0.03d0,t_final
  real(8), parameter :: one=1.0,two=2.0,four=4.0,half=0.5
  integer(4) ::steps,i,j,ip,im,jp,jm,t_start,t_end,rate
  real(8):: dt=1.0d-4,tau=0.0003d0,ep=0.01d0,ka=1.8d0,seed=5.0d0,ppo,t1,t2,th,m
  real(8):: del=0.02d0,an=6.0d0,al=0.9d0,ga=10.0d0,te=1.0d0,t0=0.2d0,pix=four*atan(one)
  real(8),dimension(Nx,Ny) :: pp,tt,lpp,ltt,ppx,ppy,eps,deps
  pp = 0.0
  tt = 0.0
  do i = 1, Nx
    do j = 1, Ny
      if ((i-Nx/two)*(i-Nx/two)+(j-Ny/two)*(j-Ny/two)<seed)pp(i,j)=one
    end do
  end do
  call system_clock (count=t_start, count_rate=rate)
  do steps = 1,1000
    do concurrent (integer::j=1:Ny,i=1:Nx) default (none)             &
      local ( ip,im,jp,jm,th )                                        &
      shared ( x,y,lpp,ltt,pp,tt,ppx,ppy,eps,deps,t0,an,del,ep )
      jp = j + 1
      jm = j - 1
      ip = i + 1
      im = i - 1
      if ( im == 0 ) im = Nx
      if ( ip == ( Nx + 1) ) ip = 1
      if ( jm == 0 ) jm = Ny
      if ( jp == ( Ny + 1) ) jp = 1
      lpp(i,j) = (pp(ip,j)+pp(im,j)+pp(i,jm)+pp(i,jp)-four*pp(i,j))/(x*y)
      ltt(i,j) = (tt(ip,j)+tt(im,j)+tt(i,jm)+tt(i,jp)-four*tt(i,j))/(x*y)
      ppx(i,j) = (pp(ip,j) - pp(im,j))/x
      ppy(i,j) = (pp(i,jp) - pp(i,jm))/y
      th  = atan2( ppy(i,j),ppx(i,j) )
      eps(i,j)  =  ep*(one+del*cos(an*(th-t0)))
      deps(i,j) = -ep*an*del*sin(an*(th-t0))
    end do
      local( i,j,ip,im,jp,jm,ppo,t1,t2,m)                                 &
      shared(x,y,pp,tt,eps,deps,ppx,ppy,lpp,ltt,al,pix,te,ga,dt,tau,ka)
      jp = j + 1
      jm = j - 1
      ip = i + 1
      im = i - 1
      ppo = pp(i,j)
      t1 =  ( eps(i,jp)*deps(i,jp)*ppx(i,jp) - eps(i,jm)*deps(i,jm)*ppx(i,jm) ) / y
      t2 = -( eps(ip,j)*deps(ip,j)*ppy(ip,j) - eps(im,j)*deps(im,j)*ppy(im,j) ) / x
      m = al/pix*atan(ga*(te-tt(i,j)))
      pp(i,j) = pp(i,j)+(dt/tau)*(t1+t2+eps(i,j)**2*lpp(i,j) ) &
      +  ppo*(one-ppo)*(ppo-half+m)
      tt(i,j) = tt(i,j)+dt*ltt(i,j)+ka*(pp(i,j)-ppo)
    end do
  end do
  call system_clock (count=t_end)
  t_final = real(max(t_end-t_start,1_8))/real(rate)
  print*, t_final
end program dc_test
ifx test
No parallelization to be seen with the output time
>ifx main_dc.f90 /Qopenmp /F500000000
Intel(R) Fortran Compiler for applications running on Intel(R) 64, Version 2024.2.0 Build 20240602
Copyright (C) 1985-2024 Intel Corporation. All rights reserved.
Microsoft (R) Incremental Linker Version 14.32.31332.0
Copyright (C) Microsoft Corporation.  All rights reserved.
-out:main_dc.exe
-subsystem:console
-stack:500000000
-defaultlib:libiomp5md.lib
-nodefaultlib:vcomp.lib
-nodefaultlib:vcompd.lib
main_dc.obj
>main_dc
   4.00899982452393
ifort test
parallelization can be confirmed with the output time
>ifort main_dc.f90 /Qopenmp /F500000000
Intel(R) Fortran Intel(R) 64 Compiler Classic for applications running on Intel(R) 64, Version 2021.13.0 Build 20240602_000000
ifort: remark #10448: Intel(R) Fortran Compiler Classic (ifort) is now deprecated and will be discontinued late 2024. Intel recommends that customers transition now to using the LLVM-based Intel(R) Fortran Compiler (ifx) for continued Windows* and Linux* support, new language support, new language features, and optimizations. Use '/Qdiag-disable:10448' to disable this message.
-out:main_dc.exe
-subsystem:console
-stack:500000000
main_dc.obj
>main_dc
0.282000005245209
Question 2) According to the intel documentation, rules for variable-name in a locality-spec: "variable-name can not be the same as index-name of the same do concurrent statement." So the code is expected to show error or warning because in the concurrent statement
i and j are index-name, I think.
Question 3)  The option /Qopt-report-phase:openmp does not work with ifx but with ifort. So how to get the report to check if ifx has successfully parallelized the code?
Labels (3)
Andrew_Smith
Valued Contributor I
The amount of work inside the do concurrent loop is probably too small compared the overhead of parallel running so it actually runs slower. You did not show comparative times for serial and parallel to prove your assumption
Fortran10
The output shows the time for both tests. It is the last line in the output.
Here I it write again
ifort time = 0.282000005245209
ifx time    = 4.00899982452393
Andrew_Smith
I used task manager and confirmed that without using the /Qopenmp flag, DO CONCURRENT does not produce parallel code.
I had to up the stack size when using /Qopenmp, no idea why as the thread data should be small as only scalar variable are declared as LOCAL
These are my results:
 SerialParallel (/Qopenmp)
IFX2.7079999454.796
IFORT2.0929999350.81
Task manager confirmed that the IFX parallel version did not run in parallel but the IFORT version did.
Devorah_H_Intel
For Question # 3
See  the Intel Fortran Compiler Porting Guide
As well as other useful information on ifx.
