29277 Discussions
ifx does not respect global values passed by reference
foxtran
New Contributor II
Assuming, that one has the following code:
main.f90:
program main
  implicit none
  common /mem/ imem
  integer :: imem
  imem = 0
  call test(imem)
end program main
subroutine update_imem
  implicit none
  common /mem/ imem
  integer :: imem
  imem = 30
end subroutine update_imem
 test.f90:
subroutine test(imem)
  integer :: imem
  print *, imem
  call update_imem()
  print *, imem
end subroutine test
Compilation:
ifx test.f90 main.f90 -O0 -o a.exe
Running gives the output:
0
30
that is expected.
However, if it will be compiled with -O3:
the output will be
0
0
The expected output should be the same as without optimisations. This behaviour is for NAG/ArmFlang/gfortran/LLVMFlang/AOCC/ifort compilers, but not for ifx.
@Ron_Green ,  could you please have a look?
Related issues:
https://community.intel.com/t5/Intel-Fortran-Compiler/pointer-to-procedure-is-constant-while-should-not/m-p/1634195
https://community.intel.com/t5/Intel-Fortran-Compiler/common-variable-passed-as-argument-of-function-is-overoptimized/m-p/1573128
Steve_Lionel
This is an invalid program. It violates:
In other words, you're aliasing the dummy argument and the COMMON variable, and that is not allowed here.
Steve_Lionel
foxtran
New Contributor II
@Steve_Lionel, thank you so much. It was a bit hard for me to understand those sentences with "unless".
So, it is time to update 40k LoC with this violation...
Steve_Lionel
You can, for now, compile with /assume:dummy_aliases and I think it should do what you want. It is still invalid code.
All of the "unless" bullets are cases where you are allowed to make aliases - the TARGET attribute (implied by POINTER, which I think is relevant to your other thread), is one of these.
One of the core tenets of Fortran is that aliasing is generally disallowed, unless you tell the compiler explicitly that it can occur.
foxtran
New Contributor II
@Steve_Lionel, thank you! With `-assume dummy_aliases`, all tests were passed. And thank you for explanation  about Fortran.
