29487 Discussions
ifx internal compiler error with huge()
Jacob_Williams
New Contributor III
The following example causes an "error #5623: Internal compiler error: internal abort" with the latest Intel ifx compiler (2024.2) on Windows 10, 64bit, using Visual Studio 2019, both Debug and Release builds:
module test
    use iso_fortran_env, only: wp => real64
    implicit none
    private
    public :: go
contains
    subroutine go()
        integer,dimension(:),allocatable :: m
        allocate(m(10))
        m = huge(1.0_wp)
    end subroutine go
end module test
V-T
The same error can also be produced with the following minimal example:
integer::i(1)
i=huge(0.)
end
JFH
V-T's 3-line program has i=huge(0.) but huge(0.) is too big to store in the integer i. Changing to i=huge(0) makes the program run.
V-T
Yes, but the problem is not with the correctness of the code. Internal compiler errors (ICEs) should not happen. If there are some syntax errors, the compiler should catch them with appropriate error messages, not with ICEs. Also, converting `huge(0.)` to an integer isn't a problem for ifx without any compiler flags, because, if you remove `(1)` in the first line, the code will compile without any problems.
Devorah_H_Intel
Thank you for reporting the ICE to us. I have been able to reproduce it internally, and the case has been escalated to compiler engineering for a fix.
