29576 Discussions
ifx wrong result with EXTENDS_TYPE_OF in array constructor at -O2
pums974
I observe a wrong result with ifx when using EXTENDS_TYPE_OF on elements of a polymorphic allocatable array inside an array constructor. The issue appears with optimization enabled, at least with -O2.
Minimal reproducer:
program bug_report
    implicit none
    type :: base_type
    end type base_type
    class(base_type), allocatable :: polymorphic_array(:)
    type(base_type) :: element
    logical :: test(2)
    allocate(polymorphic_array(2))
    test = [ &
        extends_type_of(polymorphic_array(1), element), &
        extends_type_of(polymorphic_array(2), element) &
    print *, "scalar 1:", extends_type_of(polymorphic_array(1), element)
    print *, "scalar 2:", extends_type_of(polymorphic_array(2), element)
    print *, "array:   ", test
    if (.not. all(test)) error stop "wrong result"
end program bug_report
Expected output:
 scalar 1: T
 scalar 2: T
 array:    T T
Actual output with ifx -O2:
 scalar 1: T
 scalar 2: T
 array:    F T
ERROR STOP wrong result
The two scalar calls to EXTENDS_TYPE_OF return the expected value, but the same expressions evaluated inside the array constructor assigned to test produce an incorrect first element.
Compilation commands used:
ifx -O1 bug_report.f90 && ./a.out
ifx -O2 bug_report.f90 && ./a.out
gfortran -O1 bug_report.f90 && ./a.out gfortran -O2 bug_report.f90 && ./a.out
Observed behavior:
ifx -O1: correct result
ifx -O2: wrong result, first element of test is F
gfortran -O1: correct result
gfortran -O2: correct result
Compiler version:
ifx (IFX) 2025.0.4 20241205
System information:
OS: Arch Linux
Shiquan_Su
We are taking a closer look at that.
LitSurfTry
is this thread is real or fake... If it wont help, then insuficient data reported as thread to messaging.
WRONG! test = [ &
        extends_type_of(polymorphic_array(1), element),<--------!!!!!!!! &
test = [ &
        extends_type_of(polymorphic_array(1), element) &
WRONG!    print *, "array:   ", test
    print *, "array:*", test
OR
    print *, "array:array(1)", test
    print *, "array:array(2)", test
if not all (* is missing or 1 2) then error
goodluck.
pums974
For completeness, I have a different result with the latest version of ifx
ifx (IFX) 2026.0.0 20260331
scalar 1: T
scalar 2: T
array: F F
wrong result
 now the whole array is False for some reason.
