29653 Discussions
iidb + Photran: Problems with allocatable arrays, array sections; and long load times
abhimodak
Hi
I am trying to use idb with Photran 6.0 (latest release) on red-hat Linux (32-bit). I set LD_LIBRARY_PATH and used "iidb" in place gdb in the debugger. This gets the debugger working.
However it seems the debugger cannot show allocatable arrays, array sections, and character variables. . If I type these in the "expressions" window, I see "pending". Also overall the load time for the debugger is also quite long.
Is there a step that I missing here or is this a known issue? I don't have any problems when I use the idb GUI directly.
I am using IVF update 6 i.e. 11.1.069.
Abhi
