29653 Discussions
impossible to display variable using displacement
LRaim
The following is not a new problem but I am a bit annoyed to find it when debugging.
If the following structure is defined:
​REAL(KIND=8)  VET1,VET2
​COMMON/DATA/VET1(100),VET2(50)
​one can address VET2(1) as VET1(1+JD) with JD set at 100.
​Now it is impossible to view the content of such a variable using Quick Watch in Visual Studio.
This windows displays the message 'subscript out of range' but the bound checking option has never been activated.
​Tools in use:
Microsoft Visual Studio Professional 2015 Version 14.0.25420.01 Update 3
and
Intel® Parallel Studio XE 2016 Update 4 Composer Edition for C++ Windows* Integration for Microsoft* Visual Studio* 2015, Version 16.0.125.14
​Has this problem been corrected in subsequent releases ?
andrew_4619
That isn't a bug is it. You are addressing beyond the bounds of the variable, and the debugger quite rightly says no. Yes I understand that you expect it to find vet2 at that address but why would the debugger developers want to devote effort to allowing you to do such a cludgy thing when there are valid ways of examining the contents of vet2?
LRaim
I am sorry to have no comments from Intel people about this matter. The behavior of the Intel fortran debugger shows worthless constraints revealing  a lack of specifications. This is worst than a bug.
​Whatever the language, a debugger should display the content of memory provided the address of a variable (scalar or array) is part of the address space of the application. Intel developers should at least learn from Microsoft developers.
Attached is the image of Visual Studio displaying an 'out of range' array element in C++.
​I can add that looking for an application bug it can be useful to view the content of the memory preceding the first element of an array or following the last element.
Best regards
andrew_4619
If you want to look at specific memory locations or ranges you can, for example using the memory windows.
Devorah_H_Intel
Best regards
Thank you for the report. I have escalated this. If you need further assistance please use Online Service Center.
