initializing variables
bangnet
hello,
i am using ifc to compile a big, old fortran code. is there any option that would force ifc to initialize all the variables to zero if they have not been explicitly initialized?
thanks,
barb.
bangnet
i found it myself: -zero
--barb.
> hello,
> thanks,
> barb.
efth
Since I have the same problem, can you tell me the solution ?.....
I have a similar problem, since I want to make all the variables zero in order to makeiterative runs of a code.
efth
-zero is not yet supported in Intel Fortran 8.0. It should be in an update to be released in April. Note that -zero will initialize only local scalar variables that are statically allocated.
