install problems of ifc on debian
kamaraju
Hi
I downloaded l_fc_pc_7.1.040.tar from intel website. I am not able to install it on a debian system. I could not find any documentation on how to install it on a non-rpm based distribution.
For l_fc_p_8.0.034 there was an install.sh script available. Using the -finalize-only option of this script, I was able to finalize the installation details on debian.
Could anyone tell me what I should do to make it work?
thanks
raju
rpoyner
I have been using alien to convert the intel rpm into a deb. You can then install the deb with dpkg and fix the INSTALLPATH manually, or if you have a lot of machines you may want to modify the deb to have a post-install script set up the paths for you.
See this thread on comp.lang.fortran to modify the deb
http://coding.derkeiler.com/Archive/Fortran/comp.lang.fortran/2004-03/0489.html
Russell Poyner
