29657 Discussions
installation Intel(R) Fortran Compiler 9.1 for Linux
Intel_C_Intel
hi,all
i dont know what i do for below expression :
* |> source /bin/ifortvars.sh(.csh) |
to use ifort
i install Intel Fortran Compiler 9.1 for Linux but at the end of this installation i cant
do up expression to complit it.
pleasehelp me.
Where do you see that text?
It is trying to tell you that, before you can use the ifort command, you need to use the "source" command to make ifort available. You must give the path to the ifortvars script for your compiler version, and then select either the .sh or .csh file depending on your shell. For example:
source /opt/intel/fc/9.1.034/bin/ifortars.sh
Then you can compile, for example:
ifort -o hello hello.f90
Does this help?
nimitzhunter
Quoting - ISN Admin
hi,all
to use ifort
pleasehelp me.
Just do what Steve said you'll be fine. However, I just want to clarify that if you're using Ubuntu. add the source line to the .bashrc file by doing this "gedit .bashrc" in terminal. Add it at the end of the file.
Quoting - ISN Admin
hi,all
to use ifort
pleasehelp me.
Where can I get the license file for Non-commercial Fortran 9.0.
What you do is get the non-commercial license for the current version and then follow the instructions here.
