installation problem
BENDAOU_O_
hello
I have a problem to install Intel ® Fortran Composer XE 2013 for Linux;
I have an Ubunto 12.O4 lts, 32 bit, the installation completes successfully
and at the end I added to the file ~ /. bashrc "source / opt/intel/composer_xe_2013.0.079/bin/compilervars.sh ia32 "  and I close the file after I open the terminal
I write ifort the result is" ifort: command not found ",
I write man ifort the result is" No manual entry for ifort "
I do not know what to do
please please I need your help
BENDAOU_O_
I have already did sudo apt-get install build-essential apt-get install gcc-multilib sudo apt-get install rpm apt-get install openjdk-6-jre-headless
Heinz_B_Intel
This very likely is the well known installation issue we currently face for 13.0. See http://software.intel.com/en-us/forums/topic/328087 in this forum and also http://software.intel.com/en-us/forums/topic/327606 for workarounds. I will let you know as soon as a fix is available. Heinz
BENDAOU_O_
thank you very much for your answer but what is the version of linux compatible with Fortran Composer XE 2013?
Heinz_B_Intel
Ubuntu 12.04 and 11.10 are offcially supported by compiler version 13.0; the fix of this bug in the next update will make sure, installation and use will not require workarounds
Heinz_B_Intel
We investigated the problem in more detail: The problem only occurs in case the RPM manager is installed which is unusual for Ubuntu/Debian. This is why our evaluation failed to detect the problem. To improve our testing, it would be helpful to understand, why you had to install the RPM manager. Any feedback would be great. Thanks a lot
BENDAOU_O_
if I don't install rpm it will work ?
Heinz_B_Intel
Yes - in case you don't install the RPM manager, the installation will work even without the workarounds
BENDAOU_O_
it doesn't work :(
Heinz_B_Intel
Here the steps which should make sure, the installation works until we have fixed the issue in update 1 of Composer 13.0: $ sudo rm /bin/sh $ sudo ln -s /bin/bash /bin/sh In case you tried to install the Composer XE 2013 package already, follow these 2 steps: 1. Remove the partially installed Composer package: $ sudo /opt/intel/composer_xe_2013.0.079/bin/uninstall.sh You might get an error message "Package has been installed by another user. Press enter to exit"; In this case remove the installation directory: ~$ sudo rm -rf /opt/intel/composer_xe_2013.0.079/ 2. You very likely have a corrupted RPM-date base file /root/.rpmdb. The installation will not work without removing this file. Thus $ sudo –s # mv /root/.rpmdb /root/.rpmdb.backup # exit Now Install Composer XE 2013 in the usual way $ sudo rm /bin/sh $ sudo ln -s /bin/dash /bin/sh Please let us know in case it still doesn't work; please add details like error message etc.
BENDAOU_O_
hello Mr.HeinzB I reinstalled Ubuntu and i did what you asked me for apt-get install build-essential apt-get install gcc-multilib apt-get install openjdk-6-jre-headless and after bendaou@bendaou-Compaq-610:~$ sudo rm /bin/sh bendaou@bendaou-Compaq-610:~$ $ sudo ln -s /bin/bash /bin/sh $ : commande introuvable (command not found) bendaou@bendaou-Compaq-610:~$ sudo -s [sudo] password for bendaou: bash: /usr/bin/lesspipe : /bin/sh : mauvais interpréteur: Aucun fichier ou dossier de ce type (bad interpreter: No file or directory of this type) root@bendaou-Compaq-610:~# mv /root/.rpmdb /root/.rpmdb.backup mv: impossible d'évaluer «/root/.rpmdb»: Aucun fichier ou dossier de ce type (impossible to evaluate) «/root/.rpmdb»: No file or directory of this type) root@bendaou-Compaq-610:~# exit bendaou@bendaou-Compaq-610:~/Bureau/l_fcompxe_2013.0.079$ sudo ./install.sh bendaou@bendaou-Compaq-610:~/Bureau/l_fcompxe_2013.0.079$ ./install.sh bash: ./install.sh : /bin/sh : mauvais interpréteur: Aucun fichier ou dossier de ce type (bad interpreter: No file or directory of this type)
BENDAOU_O_
installation doesn' pass
Heinz_B_Intel
I'm not sure whether you really linked /bin/bash to /bin/sh. You added the '$' in typing the command ( see your latest post). Please try again ( no need to re-install your OS): sudo ln -s /bin/bash /bin/sh sudo –s mv /root/.rpmdb /root/.rpmdb.backup // ignore error message in case file should not exist exit sudo /bin/rm -rf /opt/intel/composer_xe_2013.0.079/ < do the compiler installation > sudo rm /bin/sh sudo ln -s /bin/dash /bin/sh
BENDAOU_O_
finally it works thank you very much I added in the bashrc: /opt/intel/composer_xe_2013.0.079/bin/compilervars.sh ia32 PATH=$PATH:/opt/intel/composer_xe_2013.0.079/bin/ export PATH /opt/intel/composer_xe_2013.0.079/bin/ia32/idbvars.sh PATH=$PATH:/opt/intel/composer_xe_2013.0.079/bin/ia32/ifort export PATH
Heinz_B_Intel
Great to see this ! A note: You should not 'execute' the compilervars.sh script but 'source' it. That is do: source /opt/intel/composer_xe_2013.0.079/bin/compilervars.sh ia32 Then there is no need either to set $PATH again - the script is setting this for you correctly
BENDAOU_O_
yes you are right thank you please you have an idea about this error : source/specx.f(78): error #7911: Adding this variable to common-block-object-list causes the common block size to exceed the maximum of 2147483647 bytes
You have exceeded the size of static storage for a 32-bit address space. If you are on an x64 system, try adding "-mcmodel medium" to the compiler switches. I would also suggest that rather than putting huge arrays in COMMON that you use allocatable arrays instead.
BENDAOU_O_
hello Mr.Steve Lionel I changed ubuntu 32 bit to ubuntu 64 , I installed ifort and i compiled my makefile ;;; the problem is that the program is a makefile. it's already programmed by the author and I can't change the content ( I sent you the program) and here is the error bendaou@bendaou-Compaq-610:~/Bureau/cpa2002v009c$ make ifort -O3 -o source/specx.o -c source/specx.f source/specx.f(44): error #6502: COMMON cannot be extended beyond the beginning of a block. [WKC] & ,wkc(1),detl(msex,2),det(lengx) -----------------^ compilation aborted for source/specx.f (code 1) make: *** [source/specx.o] Erreur 1 pleaaase !!! i need your help
TimP
This indicates that you have inconsistencies in the layout between instances of the COMMON (or perhaps the source code is corrupted). It seems to say that wkc(1) has been tacked on to the beginning of a later version of the COMMON.
Heinz_B_Intel
update 1 of Composer 2013 ( version 2013.1.117 ) is available for download now at registrationcenter.intel.com. This version fixes the installation issue reported in this thread Heinz
Mus_B_
Bendaou O: I went through the same trouble u have had trying to compile the cpa2002 with intel fortran. you can change the makefile (it's legal) as the author of the code even gives these rights, he even put comments ### for alternatives as the code is platfrom dependenI . I followed Steve's suggestion by adjusting the compiler switch as -mcmodel=medium (and large) (you can do that by going to the makefile and put          flag  =  -03 -mcmodel=medium or flag = -03 -mcmodel=medium -i-dynamic as suggested in some other places) ... well it just doesnt produce the executable specx u are looking for ........... I tried the fort77 (your can easily install it in ubuntu : sudo apt-get install fort77 and change the flag to fort77) but produces errors ......... the only compiler that worked for me ,though with a poor performance compared to what someone would expect from ifort , is gfortran (again which u can easily install from ubuntu repositories) ..  if I figure out how to run it using intel fortran , I will let u know.
Check my reply in machikaneyama ....
