int() function in Fortran 77
João_A_
I have come across a problem when I use the int() function. I have an real array mEL and I want to convert some of its components to integers for comparison with real array COORDS. I have to use int() due to rounding errors in COORDS array, so ZERO is not quite zero is 3.D-77 or similar:
      DO I = 1,nLines
          IF (int(mEL(I,1)).EQ.int(COORDS(1,1)) .AND.
 1              int(mEL(I,2)).EQ.int(COORDS(2,1)) .AND.
 2              int(mEL(I,3)).EQ.int(COORDS(3,1))) THEN
          .....do something
The problem is that during the run the outcome of int(COORDS(1,1)) changes but the value of COORDS(1,1) is the same. For example:
COORDS(1,1) = 1829.0000000
During 1000 runs I get int(COORDS(1,1))=1829. However, after some runs I get: int(COORDS(1,1))=1828! but COORDS(1,1)=1829!
Any ideas why this happens?
Even stranger is when I have
COORDS(1,1) = 1829.0000000 and COORDS(1,2) = 1829.0000000 and
int(COORDS(1,1)) = 1828 and int(COORDS(1,2)) = 1829!!!
andrew_4619
You are possibly better using NINT (nearest integer) rather than INT (truncation) in your example.
It probably isn't exactly 1829 but maybe a very small amount under that rounds to 1829 when you display it with fewer digits.
andrew_4619
João_A_
Yes, I should have thought about it. Thanks for your help. I'll see if I can solve my problem with this in mind.
João_A_
@app4619: Many thanks for your suggestion!
TimP
ieee_rint in default rounding mode is just slightly different but should be more optimizable than NINT.
I think Tim means IEEE_RINT - there is no IEEE_NINT. While theoretically it would be more optimizable, in our implementation IEEE_RINT is always a function call so it can't participate in optimization.
