int8()
gryvon
The code below compiles OK. I'd be grateful for an explanation of the reason for a run-time error. However, it is executed normallywithout int8(1) in the array lower bound.
program bpro
implicit none
call bsub()
stop
end program bpro
c
subroutine bsub()
include 'binc.inc'
integer*8 :: i
i = 1
t(i) = 1.0d+0
write(6, *) t(i)
end subroutine bsub
The file 'binc.inc' contains 2 lines:
integer*8, parameter :: N = 10
real*8, dimension(int8(1):N) :: t
At run-time the result is:
forrtl: severe (157): Program Exception - access violation
Image PC Routine Line Source
t.exe 0040110F _BSUB 11 bpro.f
t.exe 0040101F _MAIN__ 3 bpro.f
Intel_C_Intel
Really sorry to break in -
I am trying to sign in as a MAC user with a NEW thread, but for the life of me, can't find a "new post" button. Any clues?
I joined and was logged in at the time.
Thanks; Bill
gryvon, that's truly bizarre. It's the use of the INT8 in the DIMENSION that triggers the problem - though INT4 would do it too. I don't understand why. I'll pass this on to the developers. Instead of INT8(1), use 1_8 - that works.
Bill, there should be a big "New Post" button at the top of the forum section, just above the listing of posts.
INT(1,8) works too (and would be standard-conformung use). Still a bug regaring INT8 and INT4....
