integer data type :long
erheiqin
I just bought VCF for window, and want to translate my c code to it. I have a question on the integer data type. Is it true that no matter which kind of integer, I can just use "integer" to define it? Is there a corresponding type "long" in C as in VCF?
Erhei
TimP
I just answered the question about big integer types on the linux forum. Define the LONG (8 byte) kind using standard Fortran syntax. The default integer in Intel Fortran is 32 bits. Windows C int and long also are 32 bits. While it does matter which kind of integer, you most likely want the default kind.
