intel MDPI internal ABORT
yabin__li
We compiled a code which is able to performe geophysics simulations.
But,the code fail with the folowing error.
Sometimes it's running normally while sometimes there is an internmal ABORT.
I'll be thankful if you can help me in fixing this prolem.
Thank you in advance,
Yabin
Assertion failed in file src/mpid/ch3/channels/nemesis/netmod/tcp/socksm.c at line 596: hdr.pkt_type == MPIDI_NEM_TCP_SOCKSM_PKT_ID_INFO || hdr.pkt_type == MPIDI_NEM_TCP_SOCKSM_PKT_TMPVC_INFO
internal ABORT - process 13
=   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
=   PID 59804 RUNNING AT em
=   EXIT CODE: 1
=   CLEANING UP REMAINING PROCESSES
=   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
