intel fortan command-line window
solisgb2
Hi
Is it possible to open a intel fortan command-line window from Visual Studio 2010 Shell?
I have tried with wiew->other windows->command windows, but I can not run commands such as cd, dir...
Luis
TimP
The command prompt shortcut which the compiler installs on Start menu automatically runs compilervars. Right click on it to see the command.
IanH
In that command window (View > Other Windows > Command Window) type:
Tools.Shell cmd.exe
But... why?
solisgb2
I'd like to use the compiler & linker from the command line
Luis
TimP
So use the shortcut which the installer puts on the Windows Start menu.
solisgb2
If I open the ms-dos window in this way, I see that environment variables are not set. I must run compilervars.bat.
It is possible to open a ms-dos windows from vs 2010 with the environmental variables already defined?
TimP
