intel fortran 2003
griflet
I'm trying to test the new fortran 2003 OO features. Fortran 2003 is quite interesting, because where I work there is a large database of fortran 95 code that we could reuse (> 700 000 lines of code) ...
Anyway, I started creating a "linked list" class with a cool-looking "for each in " method; it goes like:
type(C_Collection) :: mylist
type(C_Collection), pointer :: item => null()
do while ( mylist.forEach(item) )
end do
My goal would have been then to extend the type to any other class with "linked list" characteristics. I managed to make it work at first.
But then I went on to try to refrain the direct access to the type fields and added a layer of get and set methods; but it doesn't seem to work.
I wanted to avoid stuff like this
mylist%next => null()
by using stuff like this
call mylist.setNextPointer( null() )
but it doesn't work. I must use
ptr => null()
call mylist.setNextPointer( ptr )
so it can work.
Anyway, here's my code.
I think it should work according to fortran 2003 specifs, but it yields with ifort 11.1 in windows at compilation
catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error. compilation aborted for E:\\Projects\\griflet\\fortran\\paises\\class_colecao.F90 (code 3)
and, though it compiles, it yields a segmentation fault with ifort 12 in linux.
Anyone can help me understand what are the limitations of present limitations of intel fortran 2003?
This isn't urgent at all; it's really weekend test-drives only...
Thank you,
Cheers
Guillaume
Here's the class code.
[fortran]
[/fortran]
[fortran]  module class_collection
  !When using classes in fortran 2003, try considering that'%' and 'target'
  !are forbidden directives, except in 'get' and 'set' methods.
  !Encapsulate in special methods uses of 'associated' and return logical
  !result instead.
  implicit none
  private
  public C_Collection
  type C_Collection
    integer                         :: id = 1
    class(C_Collection), pointer       :: founder => null()
    class(C_Collection), pointer       :: next => null()
  contains
    !Constructors
    procedure                       :: init => init_list
    !Sets ( '%' allowed for writing )
    procedure                       :: defineId => defineId_node ! ( 'target' allowed )
    procedure                       :: defineFirst => defineFirst_node
    procedure                       :: defineNext => defineNext_node
    !Gets ( '%' allowed for reading)
    procedure                       :: getSelf => getSelf_node
    procedure                       :: getId => getId_node
    procedure                       :: getFirst => getFirst_node
    procedure                       :: getNext => getNext_node
    !C_Collection methods
    procedure                       :: hasFirst => hasFirst_node
    procedure                       :: hasNext => hasNext_node
    procedure                       :: add => add_node
    procedure                       :: forEach => forEach_item
    procedure                       :: get => get_node
    procedure                       :: getPrevious => getPrevious_node
    procedure                       :: getLast => getLast_node
    procedure                       :: showId => showId_node
    procedure                       :: show => show_list
    procedure                       :: remove => remove_node
    !Destructors
    procedure                       :: finalize => remove_list
  end type C_Collection
contains
  !Constructors
  subroutine init_list(self, id)
    class(C_Collection)              :: self
    class(C_Collection), pointer     :: ptr
    integer, optional             :: id
    if ( .not. self.hasFirst() ) then
      if ( present(id) ) then
        call self.defineId( id )
      end if
      ptr => self.getSelf()
      call self.defineFirst( ptr )
      ptr => null()
      call self.defineNext( ptr )
      write(*,*) 'Criado item numero ', self.getId()
    end if
  end subroutine init_list
  subroutine defineId_node(self, id)
    integer                       :: id
    self%id = id
  end subroutine defineId_node
  subroutine defineFirst_node(self, primeiro)
    class(C_Collection), pointer     :: primeiro
    self%founder => primeiro
  end subroutine defineFirst_node
  subroutine defineNext_node(self, next)
    self%next => next
  end subroutine defineNext_node
  function getSelf_node(self) result(proprio)
    class(C_Collection), target      :: self
    class(C_Collection), pointer     :: proprio
    proprio => self
  end function getSelf_node
  function getId_node(self) result(id)
    integer                        :: id
    id = self%id
  end function getId_node
  function getFirst_node(self) result(primeiro)
    primeiro => self%founder
  end function getFirst_node
  function getNext_node(self) result(next)
    class(C_Collection), pointer     :: next, ptr
    if ( self.hasNext() ) then
      next => self%next
    else
      next => null()
    end if
  end function getNext_node
  function hasFirst_node(self) result(tem)
    class(C_Collection), intent(in)  :: self
    logical                       :: tem
    primeiro => self.getFirst()
    if ( associated( primeiro ) ) then
      tem = .true.
    else
      tem = .false.
    end if
  end function hasFirst_node
  function hasNext_node(self) result(tem)
    logical                       :: tem
    next => self.getNext()
    if ( associated( next ) ) then
      tem = .true.
    else
      tem = .false.
    end if
  end function hasNext_node
  subroutine add_node(self)
    class(C_Collection), pointer     :: ultimo, new, primeiro
      call self.init()
    end if
    write(*,*)'a'
    write(*,*) 'b'
    ultimo => self.getLast()
    write(*,*) 'c'
    allocate(new)
    call new.defineId( ultimo.getId() + 1 )
    call new.defineFirst( primeiro )
    call ultimo.defineNext( new )
    write(*,*) 'Criado item numero ', new.getId()
  end subroutine add_node
  function forEach_item(self, item) result(keepup)
    !Simulates 'for each  in  do ... end do'
    !usage: do while ( Lista.forEach (item) )
    !usage: ...
    !usage: end do
    class(C_Collection), pointer, intent(inout)     :: item
    class(C_Collection), pointer                    :: itemZero => null()
    logical                                      :: keepup
    if ( .not. associated( item ) ) then
      allocate( itemZero )
      call itemZero.defineId(0)
      ptr => self.getFirst()
      call itemZero.defineFirst( ptr )
      call itemZero.defineNext( ptr )
      item => itemZero
    end if
    if ( item.hasNext() ) then
      item => item.getNext()
      keepup = .true.
    else
      item => null()
      keepup = .false.
    end if
    if ( associated( itemZero ) ) then
      deallocate( itemZero )
    end if
  end function forEach_item
  function get_node(self,id) result(node)
    class(C_Collection), pointer     :: node
    integer                       :: id
    node => self.getFirst()
    do while ( node.getId() .ne. id )
      if ( node.hasNext() ) then
        node => node.getNext()
      else
        id = node.getId()
        write(*,*) 'WARN 000: Nao se encontrou o node ', id, ' na collection.'
      end if
    end do
  end function get_node
  function getPrevious_node(self) result(anterior)
    class(C_Collection), pointer     :: anterior, next
    anterior => self.getFirst()
    if ( self.getId() .ne. anterior.getId() ) then
      next => anterior.getNext()
      do while ( next.getId() .ne. self.getId() )
        if ( next.hasNext() ) then
          anterior => anterior.getNext()
          next => next.getNext()
        else
          write(*,*) 'WARN 001: Nao foi encontrado o node anterior na collection'
          write(*,*) 'collection corrompida.'
          exit
        endif
      end do
    endif
  end function getPrevious_node
  function getLast_node(self) result(ultimo)
    ultimo => self.getSelf()
    do while ( ultimo.hasNext() )
      ultimo => ultimo.getNext()
    end do
  end function getLast_node
  subroutine showId_node(self)
    ptr => self.getPrevious()
    if ( self.getId() .eq. ptr.getId() ) then
      write(*,*) 'O item e o founder da list.'
    else
      write(*,*) 'O item anterior tem numero ', ptr.getId()
    end if
    write(*,*) 'O numero do item e o ', self.getId()
    ptr => self.getNext()
    if ( .not. self.hasNext() ) then
      write(*,*) 'O item e o ultimo da list.'
    else
      write(*,*) 'O item next tem numero', ptr.getId()
    end if
    write(*,*) ''
  end subroutine showId_node
  subroutine show_list(self)
    class(C_Collection), pointer :: item => null()
    do while ( self.forEach(item) )
      call item.showId()
    end do
    write(*,*) 'Lista mostrada.'
    write(*,*) ''
  end subroutine show_list
  subroutine remove_node(self)
    class(C_Collection), pointer    :: ultimo, preprevious, ptr
    preprevious => ultimo.getPrevious()
    if ( ultimo.getId() .eq. preprevious.getId() ) then
      write(*,*) 'WARN: A list contem apenas o seu elemento founder.'
      write(*,*) 'No se remove o elemento founder da list.'
      write(*,*) 'O elemento founder so pode ser removido externamente.'
    else
      write(*,*) 'Removido item numero ', ultimo.getId()
      deallocate(ultimo)
    endif
    ptr => null()
    call preprevious.defineNext( ptr )
  end subroutine remove_node
  !Destructors
  subroutine remove_list(self)
    class(C_Collection), pointer     :: first
    first => self.getFirst()
    do while ( first.hasNext() )
      call first.remove()
    end do
    write(*,*) 'Lista esvaziada.'
    write(*,*) ''
  end subroutine remove_list
end module class_collection
!----------------- Program -----------------------------
program unitTests_collection
  use class_collection
  implicit none
  integer                     :: i
  type(C_Collection)             :: list
  call list.init(1)
  do i = 2, 15
    call list.add()
  end do
  write(*,*) ''
  call list.show()
  call list.finalize()
  call list.show()
end program unitTests_collection
[/fortran]
First look at this tells me that there's an infinite recursion loop between HasNext and GetNext, causing the runtime error. I will look at this in more detail.
Yep, that's exactly the problem.
add_node calls self.get_last (you do understand that the use of . instead of % is non-standard?)
get_last has this:
[plain]    do while ( ultimo.hasNext() )
    end do[/plain]
and the first thing hasNext does is:
[plain]  next => self.getNext()[/plain]
So now we are in getNext and the first thing it does is:
[plain]   if ( self.hasNext() ) then[/plain]
This is an infinite recursion, blowing the stack. The end result is usually a segfault/access violation, though I have seen it simply cause the program to exit without any messages.
griflet
Hi guys,
I found my error :( The 'has' function was calling the 'get' function, and the 'get' function was calling the 'has' function, over and over again, until segmentation fault (aka stack-overflow).
The 'has' must not use the 'get' and directly read the intrinsic fields of the type ...
So, it compiles and runs well with intel fortran 12 in linux. But it doesn't compiles in intel fortran 11.1 in windows.
My problem is solved, though I'd like to know how can i make it compile with intel fortran 11.1 in windows (for which my group owns a license).
[fortran]  function hasNext_node(self) result(has)
    logical                       :: has
    if ( associated( self%next ) ) then
      has = .true.
    else
      has = .false.
    end if
  end function hasNext_node  [/fortran]
Have the license holder log in to the Intel Registration Center - it may be that you are eligible to download and use the current version, or at least a newer one. It may not be possible to find a workaround for 11.1.
griflet
Thank you Steve!
Yes, that was that! I didn't see your reply until today because i didn't hit the refresh button :)
Ok, I will see if I can get an upgrade for ifort 12 with the current license...
Another thing I changed was:
Functions that return pointers are not safe to use. In ifort 12, something like:
do while ( associated(list.getNext() )
doesn't work (yet). What does work is a function that returns a scalar variable:
do while ( list.hasNext() ).
That's why I transformed all my
next => list.getNext()
into
call list.getNext(next)
that way, the user of the class isn't lead into error.
Unfortunately, it makes the code look a lot less sexy. I like the recursiveness of using functions whenever I can... I hope that some future update of ifort will allow to use safely functions that return pointers.
Thank you for your help and I think I will continue to explore the fortran 2003 OO possibilities ...
Best regards
I tried an example that declared a function returning a pointer and using a reference to the function as an argument to ASSOCIATED. It worked exactly as I expected in 12.0.5. Can you show me a short example where it does not work? Remember that the function result starts out as undefined, so if you don't define the pointer or NULLIFY it, the results are unpredictable.
