29591 Discussions
intel fortran building problem with calling c function (window)
simsim0
Hi, I'm testing a mixed programming (fortran main and calling c function).
The fortran file (a.f) is as follows.
program test
external ddd
call ddd(5,iii)
write(*,*) iii
end
The c file (b.c) is as follows.
#include  <io.h>
void  ddd_(int *i,int *j){
*j=*i;
Then,  compiling and building was performed on the "intel oneAPI command prompt for IA32 for visual studio 2022" as follows.
D:\code\test>cl -c b.c
D:\code\test>ifort -c a.f
D:\code\test>ifort b.obj a.obj
But, linking error (LNK2019) occurred as follows.
a.obj: error LNK2019: _DDD_MAIN__....
Could you help about the linking problem?
Labels (2)
simsim0
jimdempseyatthecove
The use of external is being phased out for C interoperability. Use BIND(C)
Jim Dempsey
simsim0
thanks.
