intel fortran compilation error
newinterlfortranuser
I used intel fortan compiler to compile one of User sub in ANSYS CFX. but got the following error message:
C:\Program Files (x86)\Intel\Compiler\Fortran\10.1.025\em64t\bin\ifort -iface:cv
f -MD -fpp -include:"C:\Program Files\ANSYS Inc\v110\CFX\include" -object:winnt-
amd64\\pt_erosion.o -c pt_erosion.F
Intel Visual Fortran Compiler for applications running on Intel 64, Versio
n 10.1 Build 20080801 Package ID: w_fc_p_10.1.025
Copyright (C) 1985-2008 Intel Corporation. All rights reserved.
30 DAY EVALUATION LICENSE
ifort: NOTE: The evaluation period for this product ends on 19-nov-2008 UTC.
C:\Program Files (x86)\Intel\Compiler\Fortran\10.1.025\em64t\bin\ifort -threads
-dll -exe:.\winnt-amd64\\pt_erosion.dll winnt-amd64\\pt_erosion.o C:\Program Fil
es\ANSYS Inc\v110\CFX\lib\winnt-amd64\solver-pvm.lib
ifort: command line warning #10161: unrecognized source type 'winnt-amd64\\pt_er
osion.o'; object file assumed
ipo: error #11035: Fatal error cannot open ifconsol
ifort: error #10014: problem during multi-file optimization compilation (code 1)
An error has occurred in cfx5mkext:
exited with return code 1.
Can somebody give me some suggestion how to solve the problem?
Thanks!
Kevin_D_Intel
This error relates to not having your environment setup correctly for the Intel Fortran compiler. This issue and the recommend resolution is discussed in the ANSYS Communities forum post located here.
I suggest following their advice of starting the Intel 64 specific Intel Fortran Build Environment console from the start menu (Start > All Programs > Intel Software Development Tools > Intel Fortran Compiler 10.1.025 > Visual Fortran Build Environment for applications running on Intel 64) and then start CFX from there.
Best of luck!
Best of luck!
Thanks Kelvin. I did as you suggested, it works. thanks!
