29390 Discussions
intel fortran compiler 9.0/9.1 for windows question
xjqian
We are using VS.net 2003 and IVF9.0 or IVF9.1. Itcrashedat the following code, who can help me? thanks very much!
write(luo,avhdr) ('node','voltage',i=1,nvprln)
NOTE:
if avhdr = '(1x,1(5x,a4,1020x,'=',a7, 3x)/) '
luo=6
nvprln=1
it will crash at the "write".
if avhdr='(1x,1(5x,a4,1002x,'=',a7, 3x)/) '
it will not crash
It's ok on IVF9.x for linux, but crash on windows platform.I don't know why?
david
There's not enough information to be able to answer you. Please send a complete example and a description of the problem to Intel Premier Support.
TimP
Past Fortran platforms had smaller limits on length of character strings or text file lines, so we don't run into this often. I note, on Google search, that 1024 character line length limit is documented for a few situations in Windows, but don't find anything specific about VS.
It would also be helpful to know what the actual error message was, rather than "crashed".
xjqian
when I run our application on windows, it comes out a dialog(which
 I don't know how to past here) and our aplication ends unnormally.
the error message dialog saids:
Visual Fortran run-time error --> title
forrtl: severe(66): output statement overflows record,unit 6,file c:davidoutput.lis
Image       PC routine    Line  Source
my.exe      01D208C6 unknown unknown unknown
kernel32.dll 7C80B683 unknown unknown unknown
Best Regards!
David
xjqian
Yes, I think it's the 1024 limit. because
if avhdr = '(1x,1(5x,a4,1020x,'=',a7, 3x)/) the total output line len is: 1 + 5 + 4 + 1020 + 1 + 7 + 3 = 1041 > 1024 crashed
if avhdr = '(1x,1(5x,a4,1002x,'=',a7, 3x)/) the total output line len is : 1 + 5 + 4 + 1002 + 1 + 7 + 3 = 1023 < 1024 not crashed.
if avhdr = '(1x,1(5x,a4,1003x,'=',a7, 3x)/) the total output line len is : 1 + 5 + 4 + 1002 + 1 + 7 + 3 = 1024= 1024 crashed.
I have tested this. So I wonder it's because of 1024 output limit on PC?
Best Regards!
David
xjqian
if avhdr = '(1x,1(5x,a4,1003x,'=',a7, 3x)/) the total output line len is : 1 + 5 + 4 + 1003 + 1 + 7 + 3 = 1024= 1024 crashed.
Best Regards!
David
This should work. The limit on the length of character constants referred to is not relevamt to this program.
Please submit a complete exmple program that shows the problem to Intel Premier Support so that we can look into it.
xjqian
I have found the error. it's not the problem of IVF9.0/IVF9.1. Thanks you very much!
David
