29393 Discussions
intel fortran compiler error cannot execute binary file
pvaldez
I installed version 9.1.031 on linux redhat 5. When i type the command
ifort int_sin.f90 in the samples directory
I get an error
/opt/intel/fc/9.1.031/bin/ifort: line 33: /opt/intel/fc/9.1.031/bin/iforbin: cannot execute binary file
/opt/intel/fc/9.1.031/bin/ifort: line 33: /opt/intel/fc/9.1.031/bin/iforbin: Success
Does anyone know what this means and how to fix>
Paul
Lorri_M_Intel
If this is, in fact, an actual cut-and-paste from your command window, then I think I see the problem.
The file /opt/intel/fc/XX/bin/ifort is really a script that invokes the Fortran driver binary.
That binary is *supposed* to be called "ifortbin".
In your message, it looks like it's trying to call "iforbin" (note the missing "t")
Please check your file /opt/intel/fc/9.1.031/bin/ifort, and make sure it's invoking the correct binary.
Also - kids, don't try this at home. :-) Theoretically, you should never have to edit the ifort script, and we don't really want you to do it - or stuff like this could happen!
- Lorri
