interdependent modules and IPO
Frederic_C_
Hi all,
here a simple example of interdependent derived types:
MODULE m_common
   USE, intrinsic :: iso_fortran_env
   implicit none
   integer, parameter :: ip = INT32
   integer, parameter :: rp = REAL64
   integer(ip), parameter :: n = 80400 , maxit = 1000
   integer(8) :: count , count_scale , count_max
   integer(ip) :: i , j , k
   real(rp) :: time , rate
   TYPE vec2d
      real(rp) :: x = 0._rp
      real(rp) :: y = 0._rp
   CONTAINS
      procedure, pass(self) :: equal_vec2d
      generic :: assignment(=) => equal_vec2d
   END TYPE vec2d
CONTAINS
   PURE ELEMENTAL SUBROUTINE equal_vec2d( self , from )
      class(vec2d), intent(inout) :: self
      class(vec2d), intent(in   ) :: from
      self%x = from%x
      self%y = from%y
   END SUBROUTINE equal_vec2d
END MODULE m_common
MODULE m_data
   USE m_common
   implicit none
   TYPE subdata
      type(vec2d) :: vector
   END TYPE subdata
   TYPE somedata
      type(subdata), allocatable :: sub_array(:)
   END TYPE somedata
END MODULE m_data
PROGRAM test
   USE m_common
   USE m_data
   type(somedata) :: totest
   call system_clock( count , count_scale , count_max )
   rate = real( count_scale , 8 )
   allocate( totest%sub_array( n ) )
   time = real( count , 8 )
   do i = 1,maxit
      do k = 1,n
         vector = totest%sub_array( k )%vector
      end do
   end do
   write(6,'(ES10.2)') ( real( count , 8 ) - time ) / rate
END PROGRAM test
If I compile this program with ifort and gfortran, I obtain these time computation results:
ifort -O3 test_all.f90 -o exe ; ./exe
6.95E-04
gfortran -O3 test_all.f90 -o exe ; ./exe
6.76E-04
At this time, no problem. Now, if I split in 3 programs test1.f90 test2.f90 and test3.f90, I obtain these results:
ifort -O3 test1.f90 test2.f90 test3.f90 -o exe ; ./exe
1.04E+00
ifort -O3 -ipo test1.f90 test2.f90 test3.f90 -o exe ; ./exe
7.45E-04
gfortran -O3 test1.f90 test2.f90 test3.f90 -o exe ; ./exe
3.17E-01
gfortran -O3 -flto test1.f90 test2.f90 test3.f90 -o exe ; ./exe
1.01E-01
So, time computation differences are very very big, and I do not understand what can really explain such differences, just accessing in memory to the main derived type array values with a very short stride
If interprocedural optimization with ifort gives me back the same performance than with only one file program, it is not the case with gfortran even if an effect is found
There is a way to compile separately my modules in order to use them efficiently in a very large program calling them a lot without ipo flag ??? maybe compiling a static or shared library with my modules and then link it to my main program ???
Fred
Kevin_D_Intel
Cross posted. Refer to https://software.intel.com/en-us/node/661253 for further comments.
