internal compiler error
MR
Dear group,
the attached code produces an ice:
$ ifort -V
Intel Fortran Compiler for applications running on Intel 64, Version 10.1
Build 20080602
$ ifort mod_sympoly.f90
fortcom: Severe: **Internal compiler error: segmentation violation signal raised** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
compilation aborted for mod_sympoly.f90 (code 3)
Marco Restelli
module mod_kinds
implicit none
public :: wp
private
integer, parameter :: wp = selected_real_kind(12,307)
end module mod_kinds
module mod_symmon
use mod_kinds, only: &
wp
implicit none
public :: &
t_symmon, &
operator(*)
private
type t_symmon
real(wp) :: coeff
end type t_symmon
interface operator(*)
module procedure mult
end interface
contains
elemental function mult(m1,m2) result(m)
type(t_symmon), intent(in) :: m1, m2
type(t_symmon) :: m
m%coeff = 1.0_wp
end function mult
end module mod_symmon
module mod_sympoly
wp
use mod_symmon, only: &
t_symmon, &
operator(*)
implicit none
public :: &
t_symmon, &
t_sympol, &
operator(*)
private
type t_sympol
integer :: nmon
end type t_sympol
module procedure mult, mult_scal
end interface
interface sympoly2pascal
module procedure sympoly2pascal_xy
end interface
contains
pure function sympoly_pascal_xy(pascal_coeff) result(p)
real(wp), intent(in) :: pascal_coeff(:,:)
type(t_sympol) :: p
type(t_symmon) :: &
temp( (size(pascal_coeff,1)*(size(pascal_coeff,1)+1))/2 )
end function sympoly_pascal_xy
end module mod_sympoly
Kevin_D_Intel
Thank you for reporting this internal error Marco. Thank you for the concise test case and for noting the compiler used. I reproduced the error and will forward this to the developers and post an update with any new information I receive.
(Internal ref. CQ-48105)
Kevin_D_Intel
This internal compiler error is fixed in the 11.0 compiler updates 11.0.074 (Linux) /11.0.056 (Mac OS)
