In version 6 of digital visual fortran , ifyouget the breakpoint menu ( from the edit tab) then under the data tab of the breakpoints dialog you have "Enter the expression to be evaluated", you can insert a variable to be watched. Is there any facility under visualstudio 2008/intel 11
if in the intell 11 you click new breakpoint under the debug /breakpoints tab it referes to C programming language
It may say C, but yes, you can enter a data breakpoint that way. I will comment that data breakpoints are just as flaky in Visual Studio 2008 as they were in Visual Studio 98.
After persisting with Digital Visual Fortran, , i finally had to switch to INTEL fortran , whichi findcumbersome to use, maybe i liked the digital too much . I then asked the same question on thisthread and with the help of the two replies managed to get the answer i wanted
http://software.intel.com/en-us/forums/showthread.php?t=77180
