issue with atan() function manual
Xj_Kong
Intel® Fortran Compiler XE 13.1 User and Reference Guides
Results
The result type and kind is the same as x and is expressed in radians. The value lies in the range -pi <= ATAN2 (y, x) <= pi.
If x is not zero, the result is approximately equal to the value of arctan (y/ x).
If y > zero, the result is positive.
If y < zero, the result is negative.
If y is zero and x > zero, the result is y (so for x>0, ATAN2 ((+0.0), x) is +0.0 and ATAN2 ((-0.0), x) is -0.0).
If y is a positive real zero and x < zero, the result is pi.
If y is a negative real zero and x < zero, the result is -pi.
If x is a positive real zero, the result is pi/2.
If y is a negative real zero, the result is -pi/2.
By testing:
    type*,"(0d0,0d0)",atan2(0d0,0d0)
    type*,"(0d0,-1d0)",atan2(0d0,-1d0)
    type*,"(0d0,1d0)",atan2(0d0,1d0)
    type*,"(-1d0,0d0)",atan2(-1d0,0d0)
    type*,"(1d0,0d0)",atan2(1d0,0d0)
gives:
(0d0,0d0)   1.57079632679490
(0d0,-1d0)   3.14159265358979
(0d0,1d0)  0.000000000000000E+00
(-1d0,0d0)  -1.57079632679490
(1d0,0d0)   1.57079632679490
So the manual should allow x==y=0 instead of:
y
(Input) Must be of type real.
x
(Input) Must have the same type and kind parameters as y. If y has the value zero, x cannot have the value zero.
Besides, the second to last line in the above "Results: If x is a positive real zero, the result is pi/2" should be "If y is a positive real ....
Kong
Anthony_Richards
I hope it didn't keep you awake at night!
