29649 Discussions
latest coarray distributed memory linux guidelines
AShte
Is this tutorial: Distributed Memory Coarray Fortran with the Intel Fortran Compiler for Linux: Essential Guide by Ronald W Green, 04/12/2011 http://software.intel.com/en-us/articles/distributed-memory-coarray-fortran-with-the-intel-fortran-compiler-for-linux-essential still the best advice for linux distributed memory coarray code with ifort 14.0? I find the logic of -coarray-config-file a bit contorted. As the guilde itself says: *quote* Thus, the "CAF configuration file" is nothing more than arguments to the Intel MPI 'mpiexec' command. *end quote* So why not do away with the config file and just specify the mpirun options directly in the job submission script. An extra confusion with the config file setup is that it is not clear where to give the command line options to the coarray program: in the config file, or in the job submission script? My experience shows that the config file is the correct place. Yet the guide seems to suggest that the job submission script is the place. BTW, the guide has some typos. I can provide corrections, if needed. However, I wanted to check first in case it has been superceded by something else. Thanks Anton
