ld: warning
moby
I recently installed the Intel Fortran Compose XE 2011 compiler onto MAC OSX, but when I try to compile a simple program (e.g. "ifort hello.f90"), I get the following:
ld: warning: directory not found for option '-L/Library/Frameworks/Intel_MKL.framework/Versions/10.0.2.018/lib/em64t'
I have older versions of the compiler and mkl on the system, though I have reset all the environment variables and can't seem to figure out where this warning is coming from. Any thoughts on this?
Moby
Ron_Green
Have you checked that directory, /Library/Frameworks/Intel_MKL.framework/Versions/10.0.2.018/lib/em64t - does it exist and are the permissions OK for it?
Next, I don't know what compiler version you are using, but you will need to source either compilervars.sh or ifortvars.sh. That script should be down in your bin/ directory in the installation area:
source /opt/intel//bin/ifortvars.sh intel64
or
source /opt/intel/bin/compilervarsh.sh
Also, you haven't upgraded to Lion by chance, have you? See the warnings on this forum about Lion and older compilers.
ron
