libifportMD.dll is missing
Emmanuel_S_
I am completely new to visual fortran.
Every time I restart my computer and try to run my compiled program, it says libifportMD.dll is missing. There are no issues with compiling the program.
If I uninstall the intel fortran compiler and then reinstall it again, the problem goes away. But, if I restart my computer the problem returns.
Any ideas?
This DLL is placed in C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\compiler (and also C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler for the 64-bit version) First, look to see if the DLL is there when you see the problem. Maybe you have some software running that deletes it.
The next thing is to look at the definition of the PATH environment variable. It should include these directories. It could be that if your PATH definition is too long, Windows can arbitrarily corrupt it.
