I have Microsoft Visual Studio 2008 with Intel Visual Fortran Compiler 11.1 in my machine.
I have a problem with a DLL libraries in Intel Visual Fortran Project.
In particular, when I try to use a *.exe in other machines (without VS), is not possibile to run the executable, because the file libiomp5md.dll is not found.
How is possible to set a static libraries in intel visual project and add to project a static library (*.lib)?
Thanks in advance for support,
Best regards
I try to add the option /Qopenmp-link:static under in
Properties > Configuration Properties > Fortran > Command Line > Additional Options
and / or
Properties > Configuration Properties > Linker > Command Line > Additional Options
Moreover, I try to add libiomp5mt.lib to my project.
However, I have the same problem: the executable in other machine request libiomp5md.dll.
How can I resolve my problem?
I'm sure that i have run the new executable.
In the properties project (that is a project for QuickWin Application), with a reference to libraries, i have the settings:
- Fortran > Libraries > Runtime Library: Quickwin (other options are setting to 'No')
- Linker > Input > Additional dependencies: kernel32.lib
- Linker > Input > Ignore specific library: dfconsol.lib
It is correct add the libiomp5mt.lib file to my project?
Um, why do you find it necessary to ignore dfconsol.lib? Are you linking in CVF objects?
Show me the command options as listed under "Command Line". You should not need to reference libiomp5mt.lib. Are you using IMSL?
I try to ignore dfconsol.lib, but i have the same problem.
I use IMSL.
Command options:
/nologo /debug:full /Od /Qparallel /warn:declarations /warn:unused /warn:truncated_source /names:uppercase /module:"Debug/" /object:"Debug/" /traceback /check:bounds /check:format /check:output_conversion /libs:qwin /winapp /4Yportlib /c
Thank you
Ok, you use IMSL - that is probably the key. Which INCLUDE line do you use to specify the IMSL libraries? If it is 'LINK_FNL_SHARED.H', then you will get this problem. Instead, use 'LINK_FNL_STATIC.H'.
This is my code to specify the IMSL libraries:
INCLUDE 'link_fnl_static.h'
use ifport
Where is the problem?
Thank you for cooperation
I attach the files obtained with the /Qopenmp-link:static command.
In the previous files, I don't add /Qopenmp-link:static in order to obtain my original configuration.
Sorry
Very interesting. I am fairly confident that the reference to libiomp5md.lib is coming from IMSL, but I can't figure out why, as on my system, the IMSL link_fnl_static.h file does not name libiomp5md.lib. What are the contents of C:\Program Files\VNI\imsl\fnl600\IA32\include\dll\link_fnl_static.h ?
You can probably solve the problem by adding libiomp5md.lib to the "Ignore library" list in the linker property pages.
I resolve my problem by adding libiomp5md.lib to the "Ignore library" list in the linker property pages!!!
Thank you!!!
Baldas
This are the contents of link_fnl_static.h:
dec$objcomment lib:'imsl.lib'
dec$objcomment lib:'imslsuperlu.lib'
dec$objcomment lib:'imslscalar.lib'
dec$objcomment lib:'imslblas.lib'
dec$objcomment lib:'imsls_err.lib'
dec$objcomment lib:'imslmpistub.lib'
In the specification of link_fnl_static.h, I have this istructions:
1- INCLUDE 'link_fnl_static.h'2 - !DEC$ OBJCOMMENT LIB:'libiomp5md.lib'
3 - use ifport
Is the line 2 the problem? It is mandatory?
Yes, line 2 is the problem. You want instead:
!DEC$ OBJCOMMENT lib:'libiomp5mt.lib'
or to build your application with OpenMP enabled (and add /Qopenmp-link:static).
Normally, we recommend using the DLL form of the OpenMP library, but understand that some customers want an all-static build.
Ok.
The use of libiomp5mt.lib resolve the problem.
Thank you very much for cooperation.
