link error...
maxlox
The library are separately compiled from the main program FEAP (this is the indication of the author: there are about 1400 files), and all of them are write in fortran.
Doing the suggest, however, I obtain this:
------ Inizio rigenerazione: Progetto: feap, Configurazione: Release Win32 ------
Deleting intermediate files and output files for project 'feap', configuration 'Release|Win32'.
Compiling with Intel Fortran 9.1 C:ProgrammiIntelCompilerFortran9.1IA32...
....mainfeap75.f
....maincontact.f
Linking...
feap75.obj : error LNK2019: riferimento al simbolo esterno _PSTART@0 non risolto nella funzione _MAIN__
feap75.obj : error LNK2019: riferimento al simbolo esterno _PINSTALL@0 non risolto nella funzione _MAIN__
feap75.obj : error LNK2019: riferimento al simbolo esterno _FILNAM@0 non risolto nella funzione _MAIN__
feap75.obj : error LNK2019: riferimento al simbolo esterno _PCONTR@0 non risolto nella funzione _MAIN__
Release/feap.exe : fatal error LNK1120: 4 esterni non risolti
Build log written to "file://C:ProgrammiFEAPver75prog24apr2007feapReleaseBuildLog.htm"
feap build failed.
---------------------- Operazione completata ----------------------
Rigenerazione: 0 completate, 1 non riuscite, 0 ignorate
Please reply to an existing message thread instead of starting a new one.
Did you recompile the library using Intel Fortran? You must do so (and you should then remove the changes I suggested.)
If you need more help, please submit a support request to Intel Premier Support and attach a ZIP of your project and files, along with a description of the problem.
