29487 Discussions
link errors/warnings only in debug mode on windows VS/ifort&icc
Scott_L_
Our visual studio 2015 and intel fortran c++ 17.1 project links and build fine in Release mode.  We always get either warnings or errors in linking Debug versions.  Its annoying but not fatal.   The mismatches are in calls from Fortran to C++ projects (both built with intel compilers).   I presume some Debug flags in Fortran and C++ are not synced but I don't know enough to know what to fix.  Any help would be appreciated.
cas2map fortran main options line:
/nologo /debug:full /MP /Od /I"../Includes" /I"S:\DDS\m313133\acsys\v_procsbcgendevl\src\solutions\u023\x64/Debug" /I"S:\DDS\m313133\acsys\v_procsbcgendevl\src\solutions\datatools\x64/Debug/" /I"S:\DDS\m313133\acsys\v_procsbcgendevl\src\solutions\math\x64/Debug" /I"S:\DDS\m313133\acsys\v_procsbcgendevl\src\solutions\acsysmodule\x64/Debug" /I"S:\DDS\m313133\acsys\v_procsbcgendevl\src\solutions\v599\x64/Debug" /I"S:\DDS\m313133\acsys\v_procsbcgendevl\src\solutions\acsys\x64\Debug/" /I"S:\DDS\m313133\acsys\v_procsbcgendevl\src\solutions\geometry\x64/Debug/" /I"S:\DDS\m313133\acsys\v_procsbcgendevl\src\solutions\string\x64\Debug\/" /I"S:\DDS\m313133\acsys\v_procsbcgendevl\src\solutions\dynamite\x64/Debug/" /I"S:\DDS\m313133\acsys\v_procsbcgendevl\src\solutions\datafile\x64/Debug/" /I"S:\DDS\m313133\acsys\v_procsbcgendevl\src\solutions\xmlparser\x64/Debug" /debug-parameters:all /warn:interfaces /Qsave /module:"x64\Debug\\" /object:"x64\Debug\\" /Fd"x64\Debug\cas2map.pdb" /traceback /check:pointer /check:bounds /check:uninit /check:stack /libs:static /threads /dbglibs /c
xmlparser_c librarian command line:
/OUT:"x64\Debug\xmlparser_c.lib" /MACHINE:X64 /NODEFAULTLIB:"nafxcwd.lib" /NODEFAULTLIB:"libcmtd.lib" /NODEFAULTLIB:"libcpmtd.lib" /NOLOGO
Severity
Code
Description
Project
File
Line
Suppression State
Error
error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in xmlparser_c.lib(xml_parser.obj)
libcpmt.lib(winapisupp.obj)
Steve_Lionel
