linker and debbuger troubles
billentete00
Hi, I'm using visual fortran 66b and I currently encounter 2 problems.
First I get the following warning message during the linking operation :
"LINK : warning LNK4098: defaultlib "libcd.lib" conflicts with use of other libs; use /NODEFAULTLIB:library"
Second array visualizer does not work anymore, it now rather freezes blocking the debugger as well.
All this happened this week. I may have changed an option but couldn't find which one when comparing with my older projects...
Thank you
